Stamp counting capabilities
Is it possible to use a stamp as a counter on two inputs at the same
time? I would like to subtract one counter from the other and not
miss any counter pulses.
once. Perhaps you could use external counters.
Could you explain in more detail about the project?
Ken
guaranteed minimum pulse duration and if so what are they?
Steve
a code loop that would manually count the pulses on both pin. If your
inputs are very fast, you could use something like the PWMPAL to handle
the counting for you.
-- Jon Williams
-- Dallas Office
From: daytonacopue [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=677Z3JsqfwykbgYtziOE82aCbcy_jCoWElCI34hLc5VWi7vjPzqu0v-Q2zta1pe0Ms5toEEwg0hTT4RtKQ]turbo_tex@h...[/url
Sent: Wednesday, June 09, 2004 12:49 PM
Subject: [noparse][[/noparse]basicstamps] Stamp counting capabilities
Injection sytem. The fuel system has a send and return line. A
transducer has to be placed into each line. The transducers will
pulse 3300/liter or 7000 depending on application. The fuel pump will
pump 110 to 140 liters per hr depending on pump. For 3300
pulses/Liter usage 140 Liter/hr = 2.33 Liter/min = 7689 pulses/min =
128 pulses/sec. For 7000 pulses/Liter usage 140 Liter/hr = 2.33
Liter/min = 16310 pulses/min = 271 pulses/sec.
The two transducer pulse counts will be subtracted to determine the
pulse count of fuel used. I am reading about the Stamps and do not
know their capabilities. I thought I might have to build counters but
wanted to make sure.... I could use the counter to interupt the Stamp
to read, subtract, clear the counters, and display to update. I also
thought about sampling the pulses for frequency and calculate but it
would not be as accurate. I need accuracy...
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> I do not believe it is possible to use the count function on two
pins at
> Ken
same
I left details of the project I want to build in the post reply to
smartdim.
I looked at the PWMPAL you suggested. It looks like the ticket. Will
the PWMPAL interface to the Basic Stamp 2 OEM Module?
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> That depends on your input speed. If it's slow enough, you could
write
your
handle
> -- Jon Williams
> -- Dallas Office
> From: daytonacopue [noparse][[/noparse]mailto:turbo_tex@h...]
same
Jon Williams
From: daytonacopue [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jdlHbXyG0uIw4Ok2gBr2vTULTtl4gh9jSdt_LLGCFCbMi7GEdbADWpbzQOYYWkRzC13JrlmsCCjGhTM]turbo_tex@h...[/url
Sent: Thursday, June 10, 2004 1:48 PM
Subject: [noparse][[/noparse]basicstamps] Re: Stamp counting capabilities
Jon
smartdim.
write
your
handle
> -- Jon Williams
> -- Dallas Office
same
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
