BASIC stamps and stepper motors — Parallax Forums
edited 2004-06-10 17:58 in General Discussion
I have a BS2 that I am trying to interface with a unipolar stepper
motor. Does anyone have any suggestions as to what the best way to
do this might be. I would really appreciate any input.
    edited 2004-06-10 14:35
    Look up experiment #26 in the Stampworks. It shows how to use a unipolar
    stepper with a Stamp and a ULN2003. Bipolars are a little harder but can be
    used as well. What kind of stepper do you want to use?
    Jonathan
    www.madlabs.info
    Sent: Wednesday, June 09, 2004 10:43 AM
    Subject: [noparse][[/noparse]basicstamps] BASIC stamps and stepper motors
    > Yahoo! Groups Links
    edited 2004-06-10 14:52
    We have docs on our web site:
    http://www.parallax.com/dl/docs/prod/motors/27964.pdf
    -- Jon Williams
    -- Dallas Office
    From: jtalaman@i... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CRzaKO6LyATY7CuY45OgsWK-uwQ2IY8Jps30q29DwLriAurX-XADAwzKiwL1zEf26uK1EE9Bklw]jtalaman@i...[/url
    Sent: Wednesday, June 09, 2004 12:44 PM
    There are a few schools of thought, but to help in termonology.
    The 'contoller' is the logic device, the PC or the Stamp, but it is
    the intelegence that wants to do something.
    the "driver" is the device that receives signals from the controller
    and then sends out power to the motor. These two terms sometimes get
    lost or swapped, and there is nothing more frustrating that using one
    set of terms for hobby stuff, then trying to talk to professionals
    who use them in a different way.
    The Stamp is the CONTROLLER, the darlington or H-Bridge is the DRIVER.
    there are very complicated controllers and very complicated drivers
    so getting the termonology correct up-front should help.
    #1) motor stepping speed. how fast do you need to go ?
    When you just need to move some few hundred khz, you have lots of
    options. getting into the thousands of khz, considder a pre-packaged
    device. Getting into hundreds of thousands of khz, requires
    extensive knoledge so that is not often considders a hobby area.
    A low speed stepper will run fine with something like a ULN2803 or
    individual darlingtons. Once you start getting into high speeds, you
    have a back EMF that can be a benifit or a disaster. It can be used
    to add power back into your circuit to boost it, or it can zap your
    chips. Typically, the easiest is to use a diode and protect the
    chips.
    As you need higher speeds look into stepper driver chips of different
    types. there are quite a few.
    need more than 10,000khz? considder a pre-packaged circuit, ditto
    for anything over about 1.5 amps, and only considder an actual
    stepper driver board for machine control. These get pretty intensive
    when you need machine tool torque.
    #2) power. and this goes with torque. A stepper motor has an ohms
    law base to allow you to design things. This is the 'nameplate' text
    of the on the motor. This is NOT the limit, but the starting place
    for driver design. Current is the current is the current. If it is
    rated for 1 amp, don't expect to ever put more thru it. If you want
    a hobby driver, then you are limited to using the nameplate voltage.
    But chopper drivers are available for getting much higher performance
    from a stepper, and using much higher voltages.
    If you design a chopper driver, you not only can, but should put 20x
    the rated voltage thru the thing.
    For hobby stuff, we design with a dead short current on the motors so
    you are limited to nameplate voltage and current. Chopper drivers
    can handle the difference.
    Anyway, since you said UNI-polar, I assume you mean hobby and there
    are a bunch of simple circuits to control them.
    I think some others posted some links to notes from Parallax so start
    there.
    Dave
