ds2405 addressable switch question
I am trying to interface a ds2405 to a bs2. Can anyone tell me
if this is possible and hopefully share some code?
thanks....
ljf
thanks....
ljf
or BS2pe you can use the OWOUT and OWIN instructions to communicate with
the device. That said, I've tried that part and don't find it terribly
useful or easy to use....
-- Jon Williams
-- Dallas Office
From: lfreeze2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vjl9eKVTDaTzzPv7EyjoNvNzA71CsARbquA6tJ4u9-J2E1BLQK-li-wZiP4rvds-27HfvyJ_LPZR]lfreeze@c...[/url
Sent: Wednesday, June 09, 2004 6:22 AM
Subject: [noparse][[/noparse]basicstamps] ds2405 addressable switch question
I am trying to interface a ds2405 to a bs2. Can anyone tell me if this
is possible and hopefully share some code? thanks....
ljf
take a more than significant effort
to interface a DS2405. Can you suggest an alternative to the DS2405 that
would present a more standard
"3 wire " interface to the bs2 but would be addressable. I have done a few
goggle searches but can't seem
to find anything,
Thanks...
ljf
---- Original Message
"one wire"
Sent: Wednesday, June 09, 2004 7:48 AM
Subject: SV: [noparse][[/noparse]basicstamps] ds2405 addressable switch question
> Greetings!
> To do this you either need to use a BS2p24 or BS2p40, or you need to use
> a DS2480(b) 1-wire interface chip.
> This is because the DS2405 uses what is known as the 1-wire protocol for
> communication.
> (No, you can't 'bit-bang' it, and SERIN/SEROUT and SHIFTIN/SHIFTOUT
> can't handle this one)
> I don't have any code for that chip, but if you check the latest version
> of the manual, I believe there are some examples there. (For the BS2p
> models)
> If you're using an older BS2 model, you need to take a look at the
> DS2480 datasheet which should be available for download on
> www.maxim-ic.com
> (you'll also need the DS2405 datasheet from that site)
> Trygve
Opprinnelig melding
> Fra: lfreeze2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FBi1v69bQubgiuLfKYHGDL0APAOTKaoGCdq1y6AvKl0xt-SNwEHAHQwEVBFoZ053a0J_L7OvUEM4_g]lfreeze@c...[/url
> Sendt: 9. juni 2004 13:22
> Til: basicstamps@yahoogroups.com
> Emne: [noparse][[/noparse]basicstamps] ds2405 addressable switch question
> ljf
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> Yahoo! Groups Links
> Yahoo! Groups Links
8 I/Os.
* PCF8574 (8 IO points -- can't sink or source usable current though)
* MCP23016 (16 IO points and very stout -- I like this part)
-- Jon Williams
-- Dallas Office
From: Larry Freeze [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EYT9Vq6bKuwuKBS1JJ4NV5ws0pbe2tZCYJHfZtXpBY_oG9r-jUi6iFHF7K8dOGYyBeTJRpVjMpKmWK2G]lfreeze@c...[/url
Sent: Wednesday, June 09, 2004 9:48 AM
Subject: Re: [noparse][[/noparse]basicstamps] ds2405 addressable switch question
Thanks for the responses. after looking at the spec sheets, I think it
would take a more than significant effort to interface a DS2405. Can you
suggest an alternative to the DS2405 that would present a more standard
few goggle searches but can't seem to find anything, Thanks...
ljf
"one wire"
> Greetings!
> use a DS2480(b) 1-wire interface chip.
> for communication. (No, you can't 'bit-bang' it, and SERIN/SEROUT and
> SHIFTIN/SHIFTOUT can't handle this one)
> version of the manual, I believe there are some examples there. (For
> the BS2p
> models)
> www.maxim-ic.com
> Trygve
Opprinnelig melding
> Fra: lfreeze2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EYT9Vq6bKuwuKBS1JJ4NV5ws0pbe2tZCYJHfZtXpBY_oG9r-jUi6iFHF7K8dOGYyBeTJRpVjMpKmWK2G]lfreeze@c...[/url
> ljf
> Yahoo! Groups Links
> and
> Yahoo! Groups Links
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
