Converting IEEE 32 bit floating point to scaled integer
I was given this bit of code from a coworker who used it in a C++ program. I have tried to
get it to work on the BasicStamp to no avail. Any help is appreciated!
Julian
'{$Stamp BS2p} 'Stamp Directive (specifies BS2P)
' OEM Example Program for the Basic Stamp 2p uProcessor to
' interface with a PNI Corporation V2Xe 2 Axis Compass Module.
' This program shows how to get the Heading from the V2Xe.
' Copyright 20Dec2003, PNI Corporation
' Written by Julian Benton, Applications Engineer
' Contact: jbenton@p... , 707-566-2260 x356
'Declare Lines
SYNC CON 5 'SYNC is pin 5
SSNOT CON 7 'SSNOT is pin 7
MOSI CON 8 'MOSI is pin 8
MISO CON 9 'MISO is pin 9
SCLK CON 10 'SCLK is pin 10
'Declare Global Constants for Command Datagrams
Flag CON $AA 'Defines Sync Flag which is the first byte of any command
GetModInfo CON $1 'Defines the frame type that queries the V2Xe for
module information
ModInfoResp CON $2 'Defines the response frame type to command
GetModInfo
SetDataComponents CON $3 'Defines the frame type for the data components to
be sent back
XRaw CON $1 'Defines the Component ID for X sensor RAW Data
YRaw CON $2 'Defines the Component ID for Y sensor RAW Data
Heading CON $5 'Defines the Component ID for Heading
Mag CON $6 'Defines the Component ID for Magnetude
Dist CON $8 'Defines the Component ID for the distortion flag
CalStatus CON $9 'Defines the Component ID for calibration status
SaveConfig CON $9 'Defines the SaveConfig frame type
GetData CON $4 'Defines the frame type which queries the V2Xe for data
components
DataResp CON $5 'Defines the response to command GetData frame type
Term CON $00 'Defines Terminator which is the last byte of any
command
'Declare Variables for Response Datagrams
FlagIn VAR BYTE 'Defines Sync Flag in the response Datagram
FrameIn VAR BYTE 'Defines the Frame Type in the response Datagram
CountIn VAR BYTE 'Defines the number of components in the response
Datagram
XRawIn VAR BYTE 'Defines the XRaw ID in the response Datagram
XRawVal VAR WORD(2) 'Defines the XRaw value array in the response Datagram
YRawIn VAR BYTE 'Defines the YRaw ID in the response Datagram
YRawVal VAR WORD(2) 'Defines the YRaw value array in the response Datagram
HeadingIn VAR BYTE 'Defines the Heading ID in the response
Datagram
HeadingVAL VAR BYTE(4) 'Defines the Heading value array
CompHeading VAR WORD 'Defines the Heading
Exponent VAR BYTE 'Defines value for Heading calculation
TermIn VAR BYTE 'Defines the Terminator of the resonse Datagram
'Interface with the V2Xe
High SSNOT
LOW SSNOT 'Enable SPI Port
'Set the data componets to be read from the V2Xe (Heading and Magnitude)
LOW SYNC
PULSOUT SYNC,2 'Not required
ShiftOut MOSI,SCLK,MSBFirst,[noparse][[/noparse]Flag,SetDataComponents,$1,Heading,Term]
'Set Heading as output
Pause 1
Begin:
ShiftOut MOSI,SCLK,MSBFirst,[noparse][[/noparse]Flag,GetData,Term]
'Request output (Heading)
Loop:
ShiftIn MISO,SCLK,MSBPre,[noparse][[/noparse]FlagIn]
'Look for Sync Flag
If FlagIn <> $AA THEN Loop
ShiftIn
MISO,SCLK,MSBPre,[noparse][[/noparse]FrameIn,CountIn,HeadingIn,HeadingVal(0),HeadingVal(1),HeadingVal(2)
,HeadingVal(3),TermIn] 'Shift in data (Heading)
'IEEE 32 bit floating point to scaled integer
'Integer will be scaled * 8 (i.e. 1 = 1/8, 2 = 1/4, 3 = 3/8, 4 = 1/2 ... 8 = 1.0 )
'IEEE32 format:
'31............24...23............16...15.............8...7..............0
'S E E E E E E E E F F F F F F F F F F F F F F F F F F F F F F F
'HeadingVal(0) HeadingVal(1) HeadingVal(2) HeadingVal(3)
//For Compass Heading
'MagVal(0) MagVal(1) MagVal(2) MagVal(3)
//For Magnitude
'S = Sign
'E = Exponent
'F = Mantisa or Binary Fraction
'Number = 1.F * 2^(E-127)
'The code below will assume Sign = 0 (number is positive) for all headings
'if the heading is less than 1 degree or zero (the IEEE32 version of zero)
'IMPORTANT!!! This code truncates to the nearest decimal instead of rounding.
HeadingVal(0) = HeadingVal(0) * 2 'Shift Exponent
IF HeadingVal(1) < 128 THEN Step1
HeadingVal(0) = HeadingVal(0) + 1
Step1:
Exponent = HeadingVal(0)
Step2:
IF Exponent > 126 THEN Step3 'Zero Test
CompHeading = 0
GOTO Done
Step3:
CompHeading = 1
Loop2: 'Main loop to extract the Heading
integer information
IF Exponent = 127 THEN Done
CompHeading = CompHeading * 2
HeadingVal(1) = HeadingVal(1) * 2
IF HeadingVal(1) < 128 THEN Step4
CompHeading = CompHeading + 1
Step4:
IF HeadingVal(2) < 128 THEN Step5
HeadingVal(1) = HeadingVal(1) + 1
Step5:
HeadingVal(2) = HeadingVal(2) * 2
Exponent = Exponent - 1
GOTO Loop2
Done:
'Display Heading
DEBUG "Heading: ",DEC CompHeading, CR,10
Pause 500
GOTO Begin 'Repeat
High SSNOT 'Disable SPI Port
END
Julian
'Declare Lines
module information
GetModInfo
be sent back
components
command
Datagram
Datagram
High SSNOT
LOW SYNC
Pause 1
Begin:
Loop:
'Look for Sync Flag
ShiftIn
'IEEE32 format:
//For Magnitude
'S = Sign
'E = Exponent
Step1:
Step2:
CompHeading = 0
GOTO Done
Step3:
CompHeading = 1
integer information
Step4:
Step5:
GOTO Loop2
Done:
'Display Heading
Pause 500
GOTO Begin 'Repeat
END
What is your code supposed to do? It does not look like C++ really!
Klaus
Sent: Tuesday, June 08, 2004 9:43 PM
Subject: [noparse][[/noparse]basicstamps] Converting IEEE 32 bit floating point to scaled
integer
I have tried to
> Julian
> 'Declare Lines
> module information
> GetModInfo
to
> be sent back
> components
> command
> Datagram
> Datagram
> High SSNOT
> LOW SYNC
> Pause 1
> Begin:
> Loop:
> 'Look for Sync Flag
> ShiftIn
ingVal(2)
= 1.0 )
> 'IEEE32 format:
> //For Magnitude
> 'S = Sign
> 'E = Exponent
rounding.
> Step1:
> Step2:
> CompHeading = 0
> GOTO Done
> Step3:
> CompHeading = 1
> integer information
> Step4:
> Step5:
> GOTO Loop2
> Done:
> 'Display Heading
> Pause 500
> GOTO Begin 'Repeat
> END
> Yahoo! Groups Links
It was C++ but I have changed it to work with the Basic Stamp. The part that is giving me
problems is where I am trying to convert the IEEE 32 bit number output into an integer.
The output should be a value between 0 - 360. Right now I mostly just get 0 as an output
with an occational random number.
I keep thinking there must be an easier way, but I am new to the Basic Stamp.
Julian
--- In basicstamps@yahoogroups.com, "K de Jong" <klaus0@x> wrote:
> Hi Julian,
> Regards,
> Klaus
> From: "julianbntn" <julianb@s...>
> integer
> I have tried to
> > Julian
> > 'Declare Lines
> > module information
> > GetModInfo
> to
> > be sent back
> > components
> > command
> > Datagram
> > Datagram
> > High SSNOT
> > LOW SYNC
> > Pause 1
> > Begin:
> > Loop:
> > 'Look for Sync Flag
> > ShiftIn
> ingVal(2)
> = 1.0 )
> > 'IEEE32 format:
> > //For Magnitude
> > 'S = Sign
> > 'E = Exponent
> rounding.
> > Step1:
> > Step2:
> > CompHeading = 0
> > GOTO Done
> > Step3:
> > CompHeading = 1
> > integer information
> > Step4:
> > Step5:
> > GOTO Loop2
> > Done:
> > 'Display Heading
> > Pause 500
> > GOTO Begin 'Repeat
> > END
> > Yahoo! Groups Links
ken
have tried to
Julian
All the BS2 math help you should need can be found at
http://www.emesystems.com/BS2index.htm#math
ken
Klaus,
is giving me
an integer.
as an output
Julian
As Klaus wrote, no floating point math with the stamp, but there are ways to
get floating point numbers......
I posted a link to a sight that will help.
Or, please give a calculation example of exactly what you want,,,,,ex
Ken
Hi Julian,
I believe the Basic Stamp has no floating point type, only bit-nibble-byte
and word.
Assuming the float value comes from anywhere outside of the Stamp the
easiest approach might be to multiply the value before it comes into the
Stamp in such a way that it fits in a word size. Then, when the value is
transfered, it will be transformed to a word (=two bytes) automatically.
Values will be cut to the lowest whole number, just as is done in your
example code. Afterwards you can scale your integer value as you like.
I hope this helps a bit,
Klaus
and word.
Klaus
Sent: Tuesday, June 08, 2004 11:43 PM
Subject: [noparse][[/noparse]basicstamps] Re: Converting IEEE 32 bit floating point to scaled
integer
> Klaus,
that is giving me
into an integer.
0 as an output
Stamp.
> Julian
> > Hi Julian,
> > Regards,
> > Klaus
> > integer
program.
> > I have tried to
appreciated!
> > > Julian
> > > 'Declare Lines
> > > module information
> > > GetModInfo
components
> > to
> > > be sent back
> > > components
> > > command
> > > Datagram
Datagram
Datagram
> > > Datagram
> > > High SSNOT
Magnitude)
> > > LOW SYNC
> > > Pause 1
> > > Begin:
> > > Loop:
> > > 'Look for Sync Flag
> > > ShiftIn
> > ingVal(2)
... 8
> > = 1.0 )
> > > 'IEEE32 format:
F F
HeadingVal(3)
> > > //For Magnitude
> > > 'S = Sign
> > > 'E = Exponent
headings
zero)
> > rounding.
> > > Step1:
> > > Step2:
> > > CompHeading = 0
> > > GOTO Done
> > > Step3:
> > > CompHeading = 1
> > > integer information
> > > Step4:
> > > Step5:
> > > GOTO Loop2
> > > Done:
> > > 'Display Heading
> > > Pause 500
> > > GOTO Begin 'Repeat
> > > END
and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
"There are almost as many floating point formats as there are
compilers; each vendor seemed to use its own until IEEE stepped in
and defined the most complicated format humanly possible. Most
compiler venders and CPU designers try to adhere to the IEEE
standard, but most also take liberties with it because the full IEEE
standard includes many requirements that affect system performance..."
This comment and others from your program suggests a 23 bit mantissa
and an 8 bit exponent. The exponent offset by 127. No phantom bits.
Presumably with the decimal point is assumed to be always just to the
left of the mantissa, so the mantissa is always a number greater than
or equal to 1/2 and less than one. So, some example numbers...
N exponent mantissa mantissa represents
Number
1 EEEEEEEE=128 F=$400000 (F=0.5, binary
%0.10000000000000000000000) (Number=0.5 * 2^(128-127)=1)
2 EEEEEEEE=129 F=$400000 (F=0.5, binary
%0.10000000000000000000000) (Number=0.5 * 2^(129-127)=2)
0.5 EEEEEEEE=127 F=$400000 (F=0.5, binary
%0.10000000000000000000000) (Number=0.5 * 2^(127-127)=0.5)
360 EEEEEEEE=136 F=$B40000 (F=.703125 binary
%0.10110100000000000000000) (Number=0.703125 * 2^(136-127)=360)
This is where I am a little unclear. Is the data from the compass
indeed in units of degrees and fractional degrees? Not radians or
percent or something?
About this step,
> 'Shift Exponent
That discards the least significant bit of the exponent, which is
probably needed. Maybe it should be:
EEEEEEEE = (HeadingVal(0) <<1) + (HeadingVal(1)>>7) ' 8 bit exponent
I wonder if something like the following would work to extract the
integer degrees (0 to 360)?
finalAnswer VAR word
finalAnswer=headingVal(1) & 7f << 2 + (headingVal(2) >> 6) ' 9
bits of mantissa
finalAnswer = finalAnswer >> (136 - EEEEEEEE)
The idea is to put 9 bits of the mantissa into one word. That will
cover all integer angles up to 360 degrees. The statement works by
combining the low 7 bits of headingVal(1) with the high two bits of
headingVal(2). Then in the last statement, shift that right by the
exponent. For example, if the angle is 360 degrees, you end up with
%101101000 in finalAnswer, shifted by zero, 360 the final answer. If
the angle is 2 degrees, you end up with %100000000 in finalAnswer,
shifted by (136-129=7), resulting in %10 = 2, the final answer.
I may be way off base about how the data is represented, but if not,
the C++ transcription is needlessly complicated.
-- regards,
Tracy
>Julian
>'Declare Lines
>module information
>GetModInfo
>be sent back
>components
>command
>Datagram
>Datagram
>value array
> High SSNOT
> LOW SYNC
> Pause 1
>Begin:
> Loop:
> 'Look for Sync Flag
> ShiftIn
>... 8 = 1.0 )
>'IEEE32 format:
>F F F F F F
>HeadingVal(3)
> //For Magnitude
> 'S = Sign
> 'E = Exponent
>all headings
>version of zero)
> 'Shift Exponent
> Step1:
> Step2:
> 'Zero Test
> CompHeading = 0
> GOTO Done
> Step3:
> CompHeading = 1
> Loop2:
>integer information
> Step4:
> Step5:
> GOTO Loop2
> Done:
>'Display Heading
> Pause 500
> GOTO Begin
> 'Repeat
> High SSNOT
> 'Disable SPI Port
>END
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
You may also want to try out this new floating point coprocessor -
http://www.parallax.com/detail.asp?product_id=604-00030a
Erik Wood
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HA8GS1yipLJO9Tz8s6oTaK1Ae1cPpim-wK7x8xYKwI-sjAg1ErmQZaQvkvfiStHVGa4RZsMh7Q]smartdim@a...[/url
Sent: Tuesday, June 08, 2004 7:31 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Converting IEEE 32 bit floating point to
scaled integer
Julian,
ken
Klaus,
that
is giving me
into
an integer.
get 0
as an output
Stamp.
Julian
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Yes, I saw the coprocessor and will be purchasing one, but not all of my customers will be
using the coprocessor so I hoped to come up with another example that I could supply
them.
Julian
--- In basicstamps@yahoogroups.com, "Erik Wood" <ewood@p...> wrote:
> Julian and all,
> Erik Wood
> Parallax, Inc.
> From: smartdim@a... [noparse][[/noparse]mailto:smartdim@a...]
> scaled integer
> Julian,
> ken
> Klaus,
> that
> is giving me
> into
> an integer.
> get 0
> as an output
> Stamp.
> Julian
> Yahoo! Groups Links
> abuse@p...
It might help if we could see the 32 bit values that the compass
kicks out at a few known compass points, N-E-S-W.
-- Tracy
>Erik,
>that I could supply
>them.
>Julian
I've looked at the code you provided and it does properly convert 32-bit IEEE positive
floating point values to the truncated integer value. As Tracy points out, if the values are
known to be in the range 0 to 360 you can simplify the code using his suggestion, but it
needs to account for the implicit one bit in the mantissa for normalized IEEE numbers.
The modified code using your original variable names is as follows:
Exponent = (HeadingVal(0) << 1) + (headingVal(1) >> 7)
CompHeading = ($80 + (headingVal(1) & $7F)) << 2 + (headingVal(2) >> 6)
CompHeading = CompHeading >> (136 - Exponent)
Your original code does seem to work, but it is much less efficient with all the looping and
testing.
Since your original message indicated that you were getting lots of zeros and random
numbers it might suggest that the input values are not correct. A couple of suggestions
for testing:
You can force the headingVal to a known IEEE number and see the converted result.
e.g. the test value for 360 is:
HeadingVal(0) = $43
HeadingVal(1) = $B4
HeadingVal(2) = $00
HeadingVal(3) = $00
If you go to the uM-FPU link on the Parallax site there's a free download of the uM-FPU
Converter program. You can use this to easily generate test values and also to verify the
values coming from your instrument. If you enter a floating point number in the Input
String box it will convert to the corresponding 32-bit hex value, and if you enter a $ first it
converts from a 32-bit value to the floating equivalent.
You can also copy and paste, so if you put the following statement in your code just after
you get the heading value from your instrument:
DEBUG "$", HEX2 HeadingVal(0), HEX2 HeadingVal(1), HEX2 HeadingVal(2), HEX2
HeadingVal(3), CR
Then you can copy the resulting $xxxxxxxx string from the Terminal window and paste it
into the Input String box of the uM-FPU converter and it will show the corresponding
floating point value.
Hope this helps,
Cam
A couple more thoughts on your problem. Since your application is
compass headings you probably want rounding rather than truncation
so that 22.7 degrees becomes 23 not 22. Also, 360 degrees usually
wraps back to 0 degrees. If the values are problematic you should
also do some error checking to ensure the number really is in the
range 0 to 360. The following code is a further modification of the
earlier code to provide a robust converter that can handle any
floating point number and yields an integer in the range 0 to 359 if
the value is valid or 999 if it's an error condition. The error
condition is defined as follows:
- any number less than or equal to -0.5
- any number greater than or equal to 360.5
Code:
IF Exponent < 126 THEN
CompHeading = 0
ELSEIF (Exponent > 135) OR (HeadingVal(0) > 127) THEN
CompHeading = 999 'error condition
ELSE
CompHeading = ($80 | headingVal(1)) << 2 + (headingVal(2) >> 6)
CompHeading = CompHeading >> (135 - Exponent)
IF CompHeading.LOWBIT = 1 THEN Compheading = CompHeading + 1
Compheading = Compheading >> 1
IF Compheading = 360 THEN
Compheading = 0
ELSEIF Compheading > 360 THEN
ENDIF
ENDIF
Brief Explanation:
- the exponent is extracted
- if exponent < 126, the number is between 0.5 and -0.5 so it's
rounded to zero
- if exponent > 135, the number is larger than the 9 bits we're
converting so the 999 error is set
- if headingVal(0) > 127 the number is negative so the 999 error is
set
- ten bits are loaded into compHeading (9 integer bits and 1
rounding bit)
- compHeading is shifted right to get the value*2 with LSB bit as
the rounding bit
- if the rounding bit is set, it means the remaining fraction is
greater than or equal to 0.5, so the value is rounded up
- compHeading is shifted right to get final result
- compheading is checked for wraparound at 360, or an error
condition if > 360
This should give you a solid base for your tests. If you see any
999 values then you know you're getting reading that are out of
range. If you're still having trouble, then as Tracy suggested,
give us the hex value of headingVal(0) to (4) for N-E-S-W so we can
check the format.
e.g. put the following right after you get the reading:
DEBUG HEX2 HeadingVal(0),HEX2 HeadingVal(1),HEX2 HeadingVal(2),HEX2
HeadingVal(3),CR
Cam
