Question about RTC
Hiya fellow stampers
I am looking for a RTC preferably Dallas series, doesn't have to be, that
has a I2C buss, time-date function, EEPROM, and most important alarm
interrupt outputs. really need 2 outputs. I found plenty out there but none
had an alarm interrupt output pin.
I need this so the BS2 could avoid polling the RTC and continue doing other
things until interrupted.
any ideas appreciated
Daryl
Daryl
output ,http://www.parallax.com/detail.asp?product_id=27962
Stan
--- In basicstamps@yahoogroups.com, Daryl Berryhill <djberry@h...>
be, that
alarm
but none
doing other
> Daryl
This is a I2C rtc with builtin eeprom and supervisory circuitry (watchdog,
power-on-reset),
backup battery input, 2 alarm registers: the chip tests for 2 individual
date/time
alarms and sets a bit in the status register if matched. This status
register must be polled
but you don't need to compare alarm settings against current time.
regards peter
Sent: Tuesday, June 08, 2004 4:46 AM
Subject: [noparse][[/noparse]basicstamps] Question about RTC
none
other
> Daryl
> Yahoo! Groups Links
sense of the term. If I understand you, though,
you just want the BS2 to 'poll' a single "alarm pin",
instead of having to read the current time again
and again and again.
If so, then the other posts have the solution
for you.
be, that
alarm
but none
doing other
> Daryl
pins need to be external. They will be connected to an I/O pin. when the
time matches the alarm time it changes state the BS2 will know to read the
register. also rather have a DIP than smt type.
At 10:42 PM 6/7/2004, you wrote:
>Check out the Xicor X1227 (http://www.xicor.com)
>power-on-reset),
>date/time
>regards peter
>From: "Daryl Berryhill" <djberry@h...>
>none
>other
> > Daryl
> > Yahoo! Groups Links
>Yahoo! Groups Links
use a digital alarm clock with dual outputs (relays) that you
plug directly into the AC power wall socket.
These clocks are not to expensive and have usually a small
lcd display and advanced relay trigger functions.
regards peter
Sent: Wednesday, June 09, 2004 5:32 AM
Subject: Re: [noparse][[/noparse]basicstamps] Question about RTC
> the X1227 sounds like a perfect match. with one slight problem. the alarm
(watchdog,
> >power-on-reset),
> >date/time
> >regards peter
that
> >none
> >other
> > > Daryl
and
> > > Yahoo! Groups Links
> >Yahoo! Groups Links
> Yahoo! Groups Links
be, that
alarm
but none
doing other
> Daryl
Hi Daryl,
it sounds like you want a programmable alarm and not just a clock
chip.
The BS2 is the thing that would look at the clock and then decide
when to do something.
A second micro (BS1 ?) could watch the clock and then create the
alarm output, but that is adding a lot of complication to a simple
circuit.
Dave
The Philips PCF8593 is a very nice I2C RTC in an 8-pin DIP that has
alarm registers and an interrupt pin. The interrupt pin is highly
useful and programmable for one-time date/time alarm, weekday alarms
or for a low frequency timer output. The PCF8583 is the same except
that it also includes 240 bytes of general purpose RAM.
I am not sure if Parallax has one of those available for sale. It
does not come up in search.
-- Tracy
>be, that
>alarm
>but none
>doing other
> > Daryl
thanks for the info. this is Exactly what I was looking for. The extra ram
is nice to. all I needed was 32 bytes. Unfortunately Digikey or mouser
doesn't stock it. I was able to find it at www.arrow.com for
2.78. Learned something I didn't know. This IC comes in the SOT-97-1
package. which is the same thing as a DIP8 only smaller.
Someone said, I think it was Dave, to use a BS1 as a secondary controller.
excellent idea. guess I could use it as my main controller. since I'm using
(2) PCF8574 I/O expanders and PCF8583 RTC/alarm/ram. with some custom I2C
routines, the BS1 should fit the bill.
The project I'm working on is just a simple 8 channel On/Off timer for
outside lighting with inputs for 8 motion sensors. using 8 fused SSR's to
handle the load. (because they were free) certain lights will come on for a
length of time or when triggered by motion.
oh yeah, Samsung mobile phone wall-wart charger makes a nice 5V power
source. When I opened the case was surprised to find a small SMPS giving
out 5V @ 1A. That was the best $1 spent at a thrift store. Yicks!! guess
I'm getting a little O/T .. oh well..
Daryl
At 11:09 AM 6/9/2004, you wrote:
>Hi Daryl,
> -- Tracy
> >be, that
> >alarm
> >but none
> >doing other
> > > Daryl
>Yahoo! Groups Links
