One TTL serin get info from two TTL serout pin
Stein-
One alternative: an OR-gate (inverted polarity) or AND-gate (true
polarity). Feed the two serial sources to the gate inputs, and the
gate output to the Stamp pin.
Or, if you get to control how the serial sources operate, use an open
drain/source approach.
Steve
On 7 Jun 04 at 22:08, Oystein Frostad wrote:
> ...possible to get data from two serout sources into a stamp, if I
> mount a diode or resistor (or other device), to protect the serout
> sources?
Steve
> sources?
