eb500
hi,
did anyone try to connect eb500 directly to BS2 without any parallex
boards? I've tried to connect
eb500 PIN 1 to BS2 GND
eb500 PIN 3 to BS2 TX
eb500 PIN 4 to BS2 RX
eb500 PIN 20 to BS2 VSS
But it seems not working, not light at all, any clues?
slimboyfatboyslim
http://www.slimboyfatboyslim.org
slimboyfatboyslim
Looks like you have the TX/RX backwards. Have you tried reversing them? The
Stamp should SEROUT to pin 4 of the EB500, and SERIN on pin 3. If that
doesn't work, have you:
Checked the baud rate.
Reset to default baud rate.
Made sure the code is using the correct pins.
Removed all checks on the Connection Status pin since you are not using it.
Looked with a 'scope to see if you are getting anything.
Removed any SERIN statements that wait for the ACK.
HTH,
Jonathan
www.madlabs.info
Sent: Monday, June 07, 2004 9:53 AM
Subject: [noparse][[/noparse]basicstamps] eb500
> hi,
> slimboyfatboyslim
> Yahoo! Groups Links
I did that already but still there's no response, BTW, do I need to
connect the eb500 to a serial port first and config it, then connect
the eb500 to BS?
or just connect eb500 to BS directly? how can I configure it then?
©ó 2004¦~6¤ë7¤é ¤U¤È8:54 ®É¡AJonathan Peakall ´£¨ì¡G
> Slim,
> them? The
> using it.
> HTH,
> Jonathan
> www.madlabs.info
> From: "Annie Wan" <o_wan@y...>
>> hi,
>> slimboyfatboyslim
>> and
>> Yahoo! Groups Links
> and Body of the message will be ignored.
> Yahoo! Groups Links
slimboyfatboyslim
I'm not quite sure what you are trying to do. Is it:
BS2+EB500
EB500+PC
Are you saying you can't get two EB500s to talk to each other? Or are you
saying that you can't get the BS2 to talk to an EB500?
Jonathan
Sent: Tuesday, June 08, 2004 11:16 AM
Subject: Re: [noparse][[/noparse]basicstamps] eb500
> hi,
> the eb500 to BS?
> > Slim,
> > them? The
> > using it.
> > HTH,
> > Jonathan
> > www.madlabs.info
> >> hi,
> >> slimboyfatboyslim
> >> and
> >> Yahoo! Groups Links
> > Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
in PC, I suppose the eb500 act ac a serial module replacement, am I
buying the right stuff?
©ó 2004¦~6¤ë9¤é ¤U¤È4:10 ®É¡AJonathan Peakall ´£¨ì¡G
> Slim,
> BS2+EB500
EB500+PC
> you
> Jonathan
>> hi,
>> the eb500 to BS?
>>> Slim,
>>> them? The
>>> that
>>> using it.
>>> HTH,
>>> Jonathan
>>> www.madlabs.info
>>>> hi,
>>>> slimboyfatboyslim
>>>> Subject
>>>> and
>>>> Yahoo! Groups Links
>>> Yahoo! Groups Links
>> slimboyfatboyslim
>> and
>> Yahoo! Groups Links
> Yahoo! Groups Links
slimboyfatboyslim
OK, I have done exactly waht you want to do, so I know it can be done. I
have a Stamp and EB500 hooked up on my desk right now. If I understand you
correctly, you are having trouble getting the EB500 and the Stamp to work
together.
Did you try all the things I listed in the first message? When you send a
command to the EB500, do you get and ACK or NCK?
Post the code you are using. It sounds like the problem is there.
Jonathan
www.madlabs.info
Sent: Wednesday, June 09, 2004 9:12 AM
> I want to attach the eb500 to BS and then using a bluetooth USB dongle
> > Slim,
> > BS2+EB500
EB500+PC
> > you
> > Jonathan
> >> hi,
> >> the eb500 to BS?
> >>> Slim,
> >>> them? The
> >>> that
> >>> using it.
> >>> HTH,
> >>> Jonathan
> >>> www.madlabs.info
> >>>> hi,
> >>>> slimboyfatboyslim
> >>>> Subject
> >>>> and
> >>>> Yahoo! Groups Links
> >>> Yahoo! Groups Links
> >> slimboyfatboyslim
> >> and
> >> Yahoo! Groups Links
> > Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
yup exactly, I think hooking up BS and eb500 is the 1st step, I'm still
in there, not even talking with the bt USB dongle
I've done what you've told me but even the USB bt can't detect another
bt exist and there's no light flashing or being lit in the eb500.
>>>>> eb500 PIN 3 to BS2 Rx
>>>>> eb500 PIN 4 to BS2 Tx
©ó 2004¦~6¤ë9¤é ¤U¤È9:35 ®É¡AJonathan Peakall ´£¨ì¡G
> Slim,
> I
> you
> work
> together.
> send a
> Jonathan
> www.madlabs.info
>>> Slim,
>>> BS2+EB500
EB500+PC
>>> you
>>> Jonathan
>>>> hi,
>>>> the eb500 to BS?
>>>>> Slim,
>>>>> them? The
>>>>> that
>>>>> using it.
>>>>> HTH,
>>>>> Jonathan
>>>>> www.madlabs.info
>>>>>> hi,
>>>>>> parallex
>>>>>> slimboyfatboyslim
>>>>>> Subject
>>>>>> and
>>>>>> Yahoo! Groups Links
>>>>> Subject
>>>>> Yahoo! Groups Links
>>>> slimboyfatboyslim
>>>> Subject
>>>> and
>>>> Yahoo! Groups Links
>>> Yahoo! Groups Links
>> slimboyfatboyslim
>> and
>> Yahoo! Groups Links
> Yahoo! Groups Links
slimboyfatboyslim
Does the EB500 status LED blink when you power on the unit? If not, it might
be dead. If it does, post the code you are trying to use.
Jonathan
www.madlabs.info
Sent: Wednesday, June 09, 2004 1:07 PM
> hi,
> > Slim,
> > I
> > you
> > work
> > together.
> > send a
> > Jonathan
> > www.madlabs.info
> >>> Slim,
> >>> BS2+EB500
EB500+PC
> >>> you
> >>> Jonathan
> >>>> hi,
> >>>> the eb500 to BS?
> >>>>> Slim,
> >>>>> them? The
> >>>>> that
> >>>>> using it.
> >>>>> HTH,
> >>>>> Jonathan
> >>>>> www.madlabs.info
> >>>>>> hi,
> >>>>>> parallex
> >>>>>> slimboyfatboyslim
> >>>>>> Subject
> >>>>>> and
> >>>>>> Yahoo! Groups Links
> >>>>> Subject
> >>>>> Yahoo! Groups Links
> >>>> slimboyfatboyslim
> >>>> Subject
> >>>> and
> >>>> Yahoo! Groups Links
> >>> Yahoo! Groups Links
> >> slimboyfatboyslim
> >> and
> >> Yahoo! Groups Links
> > Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
eb500, I tried to switch from command mode to data mode but it fails,
I believe that there's some problem but not totally dead, can anyone
from parallex reply this email?
Can I get a new one, I've just brought it and shipped to me this week
and I definitely need to use it ASAP.
Annie
©ó 2004¦~6¤ë9¤é ¤U¤È10:30 ®É¡AJonathan Peakall ´£¨ì¡G
> Slim,
> might
> Jonathan
> www.madlabs.info
>> hi,
>> still
>>> Slim,
>>> done.
>>> I
>>> understand
>>> you
>>> work
>>> together.
>>> send a
>>> Jonathan
>>> www.madlabs.info
>>>> dongle
>>>>> Slim,
>>>>> BS2+EB500
EB500+PC
>>>>> are
>>>>> you
>>>>> Jonathan
>>>>>> hi,
>>>>>> to
>>>>>> connect
>>>>>> the eb500 to BS?
>>>>>>> Slim,
>>>>>>> them? The
>>>>>>> that
>>>>>>> using it.
>>>>>>> HTH,
>>>>>>> Jonathan
>>>>>>> www.madlabs.info
>>>>>>>> hi,
>>>>>>>> parallex
>>>>>>>> slimboyfatboyslim
>>>>>>>> Subject
>>>>>>>> and
>>>>>>>> Yahoo! Groups Links
>>>>>>> Subject
>>>>>>> Yahoo! Groups Links
>>>>>> slimboyfatboyslim
>>>>>> Subject
>>>>>> and
>>>>>> Yahoo! Groups Links
>>>>> Subject
>>>>> Yahoo! Groups Links
>>>> slimboyfatboyslim
>>>> Subject
>>>> and
>>>> Yahoo! Groups Links
>>> Yahoo! Groups Links
>> slimboyfatboyslim
>> and
>> Yahoo! Groups Links
> Yahoo! Groups Links
slimboyfatboyslim
If you are sure it doesn't blink, even real briefly, then I would call
Parallax and talk to them. They are great.
We still haven't seen the code you are trying to use. Post it up for us to
look at.
Jonathan
www.madlabs.info
Sent: Thursday, June 10, 2004 10:42 AM
> it doesn't blink but my BT dongle detect eb500 with the device name
> Annie
> > Slim,
> > might
> > Jonathan
> > www.madlabs.info
> >> hi,
> >> still
> >>> Slim,
> >>> done.
> >>> I
> >>> understand
> >>> you
> >>> work
> >>> together.
> >>> send a
> >>> Jonathan
> >>> www.madlabs.info
> >>>> dongle
> >>>>> Slim,
> >>>>> BS2+EB500
EB500+PC
> >>>>> are
> >>>>> you
> >>>>> Jonathan
> >>>>>> hi,
> >>>>>> to
> >>>>>> connect
> >>>>>> the eb500 to BS?
> >>>>>>> Slim,
> >>>>>>> them? The
> >>>>>>> that
> >>>>>>> using it.
> >>>>>>> HTH,
> >>>>>>> Jonathan
> >>>>>>> www.madlabs.info
> >>>>>>>> hi,
> >>>>>>>> parallex
> >>>>>>>> slimboyfatboyslim
> >>>>>>>> Subject
> >>>>>>>> and
> >>>>>>>> Yahoo! Groups Links
> >>>>>>> Subject
> >>>>>>> Yahoo! Groups Links
> >>>>>> slimboyfatboyslim
> >>>>>> Subject
> >>>>>> and
> >>>>>> Yahoo! Groups Links
> >>>>> Subject
> >>>>> Yahoo! Groups Links
> >>>> slimboyfatboyslim
> >>>> Subject
> >>>> and
> >>>> Yahoo! Groups Links
> >>> Yahoo! Groups Links
> >> slimboyfatboyslim
> >> and
> >> Yahoo! Groups Links
> > Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
at all
ok, thanks
©ó 2004¦~6¤ë10¤é ¤U¤È8:30 ®É¡AJonathan Peakall ´£¨ì¡G
> Annie,
> us to
> look at.
> Jonathan
> www.madlabs.info
>> Annie
>>> Slim,
>>> it
>>> might
>>> Jonathan
>>> www.madlabs.info
>>>> hi,
>>>> still
>>>> another
>>>>> Slim,
>>>>> done.
>>>>> I
>>>>> understand
>>>>> you
>>>>> to
>>>>> work
>>>>> together.
>>>>> send a
>>>>> Jonathan
>>>>> www.madlabs.info
>>>>>> dongle
>>>>>> I
>>>>>>> Slim,
>>>>>>> BS2+EB500
EB500+PC
>>>>>>> are
>>>>>>> you
>>>>>>> Jonathan
>>>>>>>> hi,
>>>>>>>> to
>>>>>>>> connect
>>>>>>>> the eb500 to BS?
>>>>>>>> then?
>>>>>>>>> Slim,
>>>>>>>>> reversing
>>>>>>>>> them? The
>>>>>>>>> If
>>>>>>>>> that
>>>>>>>>> not
>>>>>>>>> using it.
>>>>>>>>> HTH,
>>>>>>>>> Jonathan
>>>>>>>>> www.madlabs.info
>>>>>>>>>> hi,
>>>>>>>>>> parallex
>>>>>>>>>> slimboyfatboyslim
>>>>>>>>>> Subject
>>>>>>>>>> and
>>>>>>>>>> Yahoo! Groups Links
>>>>>>>>> Subject
>>>>>>>>> Yahoo! Groups Links
>>>>>>>> slimboyfatboyslim
>>>>>>>> Subject
>>>>>>>> and
>>>>>>>> Yahoo! Groups Links
>>>>>>> Subject
>>>>>>> Yahoo! Groups Links
>>>>>> slimboyfatboyslim
>>>>>> Subject
>>>>>> and
>>>>>> Yahoo! Groups Links
>>>>> Subject
>>>>> Yahoo! Groups Links
>>>> slimboyfatboyslim
>>>> Subject
>>>> and
>>>> Yahoo! Groups Links
>>> Yahoo! Groups Links
>> slimboyfatboyslim
>> and
>> Yahoo! Groups Links
> Yahoo! Groups Links
slimboyfatboyslim
