BS2 Math Help
I could use some help or clarification with some BS2 math.
Using the the Multiply High operator (**) returns the upper byte if there is
an overflow.
For example:
24,414 * 4096 = 100,000,000.00, but the stamp should return a value of $E100
while'
24414 ** 4096 will return $5F5
How can I use the Multiply High operator along with the lower byte result to
extract 1000 from 100,000,000.00 (combining the result of the * and the **
operators)?
Or.....
24414 * 2000 = 48,828,000, but again the stamp will return only the lower
byte of $0E60
and 24414 ** 2000 will return $2E9
The end result I would want from this operation is 4882 (actually 0.4882, but
I can deal with the decimal point and leading zero easy enough if I can
extract 4882).
I cannot seem to figure out the algorithm using the * and ** operators to get
the desired results described above.
Is it possible, and can somebody get me pointed in the right direction, or is
the direction a PAKI from AWC or a uM-FPU co-processor to work with the stamp?
Thanks for the feedback.
Ken
an overflow.
For example:
while'
operators)?
Or.....
byte of $0E60
extract 4882).
Ken
This might be a good time to dig into...
http://www.emesystems.com/BS2math6.htm
There is a program there that kicks out the decimal digits of the
double precision number
/BS2math6.htm#showdubdec
You have a 32 bit number broken into two words in the Stamp
' example
elephant0 = 24414 * 4096 ' low word = $E100 = 57600
elephant1 = 24414 ** 4096 ' high word = $5f5 = 1525
DEBUG IHEX elephant1, HEX elephant0 ' prints $5f5e100
' which is 100000000 in decimal.
To get the answer in decimal, you have to program in a conversion
from base 2 to base 10. The Stamp does that for you with single
words, but not double precision. There is no easy way.
It is really base 2^16=65536, word-size chunks, written like this:
100000000 = 1525 * 65536 + 57600
The high word contains 1525, and 57600 is in the low word. The
algorithm divides that double precision number repeatedly by 10 to
get a quotient and a remainder until it extracts all the base 10
digits.
Yes, you can do that with a coprocessor, but from the standpoint of
program execution, balance the time required for the algorithm
against the time it takes to move the operands into and out of the
coprocessor.
-- Tracy
>an overflow.
>For example:
>while'
>operators)?
>Or.....
>byte of $0E60
>extract 4882).
>Ken
Time required for the algorithm should not be a factor, unless it takes more
than 200mS or so. I will check it out.
I will visit the links suggested, and should be on my way.
Thank you again,
Ken
coprocessor.
-- Tracy
Thanks again for the link to your websight on Basic Stamp Math. The
conversion to extract the decimal digits work great.....but you already knew
that!!!!!!!!!!
Dang, beat my head against a wall for a week after I learned about the **
operator, I obviously could not figure out how to extract the data from the
double precision number. Also, thanks for explaining the algorithm, that goes a lot
farther than just posting the code.
I found what I believe is a typo in the web page
http://www.emesystems.com/BS2math6.htm#multiplication
<snip>
loop:
debug cr,"xxxx:"
serin 16,$54,[noparse][[/noparse]hex4 x0] ' you enter the first number (HEX)
debug cr,"yyyy:"
serin 16,$54,[noparse][[/noparse]hex4 y0] ' you enter the second number (HEX)
z0= x0 * y0 ' low word of product
z1= x0 ** x0 ' high word of product
<end snip>
Please correct me if wrong, the last line should read:
z1=x0 ** y0.....not z1=x0 ** x0
Yes/No?
Ken
Thanks for the feedback. I went in and corrected that typo with x0 ** y0.
-- best regards,
Tracy
>Tracy,
>that!!!!!!!!!!
>that goes a lot
><snip>
>loop:
>debug cr,"xxxx:"
>debug cr,"yyyy:"
><end snip>
>Yes/No?
>Ken
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
