i/o formatters
In a message dated 6/5/2004 3:26:37 PM Eastern Daylight Time,
franksmith512@y... writes:
> I/o formatters are available for the SERIN/OUT, I2, OW, and LCD.
> Are they available where else?
Debug, shiftin/shiftout.
Sid
Sid
I have decimal variables that I wish to convert to strings in
memory. Is there a way to do it?
Could use my LCD, but don't want the code dependent on it. Used to
do that, but then my code would fail if the LCD wasn't functioning.
I know that may sound odd, but those wire connections on the LCDs are
fragile. They have been solid since I resoldered them all.
Frank
>Sid
Sid -
I don't believe SHIFTIN and SHIFTOUT support formatters, but I may be wrong.
Bruce
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
X VAR Word
SOUP VAR Byte(5)
I VAR Nib
X=54321
FOR I=0 to 4 ' ascii digits to memory array
SOUP(I)=X DIG I + 48
NEXT
FOR I= 4 to 0 ' show ascii memory array
DEBUG SOUP(I)
NEXT
END
The only other one that supports format modifiers is DEBUG, which is
really just a special case of SERIN/OUT.
-- Tracy
>Hi Everyone!
>Thanks,
>Frank
to stick to.
Frank
BTW,
Am using your stack example. My project now spans all eight
programming banks. I bounce all over the banks with ease!
Yes. I know you have another preference. Just saying thanks. It
really helped my project.
FS
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> You should look into the DIG operator in the manual or HELP.
> X VAR Word
> SOUP VAR Byte(5)
> I VAR Nib
> X=54321
> NEXT
> DEBUG SOUP(I)
> NEXT
> END
is
> -- Tracy
> >Hi Everyone!
functioning.
are
> >Thanks,
> >Frank
storage. If you convert it to a string ("123") you are now consuming
two extra bytes. The only [noparse][[/noparse]useful] thing you can do with the string is
display it; and since you can do that on-the-fly, why not?
-- Jon Williams
-- Dallas Office
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kt3-2gcgnyXAoTyaBf5XkNn2Hep4Zee70ccLHivXQeLStZ0d3RLuOxmN5lmPHu9NiFFGaA2nV9IXrdzWUhiJ]franksmith512@y...[/url
Sent: Saturday, June 05, 2004 2:02 PM
Subject: [noparse][[/noparse]basicstamps] i/o formatters
Hi Everyone!
Frank
