At wits end reading NMEA GPS sentence
I am trying to read NMEA data being transmitted from a Garmin 35-PC
GPS unit which is sending a standard GRMC sentence every second at
4800 baud to my BS2p40 via a max232 chip. The GPS transmits fine to
my windows Hyper Terminal so I know it's working fine. However when I
try to read the data in the BS2p40 I get junk data (looks like an
eastern european language). I have reviewed the electronics
scrupulously and know my Max232 and its associated caps are set up
correctly (the data enters pin 13 and exits pin 12). I think it must
be the code. I'm just using some simple code shown below.
' {$STAMP BS2p}
MyByte VAR Byte
PAUSE 250
DEBUG CLS
Main:
SERIN 0, 16884, 1500, No_GPS_Data, [noparse][[/noparse]MyByte]
DEBUG MyByte
GOTO Main
No_GPS_Data:
DEBUG "No Data"
GOTO Main
I also tried replacing the above SERIN command with:
SERIN 0, 16884, 1500, No_GPS_Data, [noparse][[/noparse]WAIT("GPRMC,"), SPSTR 65]
and the program just hangs waiting.
I've tried just about everything and after several days of
frustration I am hoping someone can point me in the right direction.
Kind Regards,
Eric
' {$STAMP BS2p}
MyByte VAR Byte
PAUSE 250
DEBUG CLS
Main:
DEBUG MyByte
GOTO Main
No_GPS_Data:
DEBUG "No Data"
GOTO Main
Kind Regards,
Eric
change the baud rate parameter to 500 for 4800 baud on the BS2p.
-- Jon Williams
-- Dallas Office
From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WA6vKX_wcHQj7NgoYhVYjurWNHW3pNNrPjEJplti6WKfAYIElF1O_xSXiP_aOgQVlIJd3Z-6tKEANQ]khufumen@y...[/url
Sent: Tuesday, June 01, 2004 12:33 PM
Subject: [noparse][[/noparse]basicstamps] At wits end reading NMEA GPS sentence
' {$STAMP BS2p}
MyByte VAR Byte
PAUSE 250
DEBUG CLS
Main:
DEBUG MyByte
GOTO Main
No_GPS_Data:
DEBUG "No Data"
GOTO Main
Kind Regards,
Eric
I tried the 500 baud rate parameter as well as every
other one listed for the BS2p with no effect. I have
the max232 there to convert the incoming GPS data from
RS232 levels to TTL levels. Wouldn't the stamp get
hurt if I fed the signal directly to the pin?
Eric
--- Jon Williams <jwilliams@p...> wrote:
> Maybe your data is getting double inverted. Remove
> your MAX232 or
> on the BS2p.
> -- Jon Williams
> -- Dallas Office
> From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mROAU0Xx4temlRKW7P66V6tDzRwdlsKFvz7bz5GxUmHOh8VvTwFDMOOhxttifwquat6ICFqJwO5d57EoxQ]khufumen@y...[/url
> sentence
> a Garmin 35-PC
> every second at
> transmits fine to
> (looks like an
> electronics
> caps are set up
> I think it must
> below.
> ' {$STAMP BS2p}
> MyByte VAR Byte
> PAUSE 250
> DEBUG CLS
> Main:
> DEBUG MyByte
> GOTO Main
> No_GPS_Data:
> DEBUG "No Data"
> GOTO Main
> SPSTR 65]
> days of
> right direction.
> Kind Regards,
> Eric
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
Stamp through a 22K resistor (protects the pin if it accidentally gets
made an output). I've done this with serial devices on several
occasions. Honestly, I don't know why you're having problems. I've
used the Garmin eTrex in more than a few projects and have never had any
difficulty with it. I know you're using a different model, but you
should still have success.
-- Jon Williams
-- Dallas Office
From: Eric [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YObdy4loq_PlfnbIuQqODzLs7lDKeVnSFAM4r002PSYHDgNm6A7kniEe-5CND_fKC-gvaiXf851Ndh4Txg]khufumen@y...[/url
Sent: Tuesday, June 01, 2004 12:55 PM
Subject: RE: [noparse][[/noparse]basicstamps] At wits end reading NMEA GPS sentence
Jon,
Eric
> your MAX232 or
> on the BS2p.
> -- Jon Williams
> -- Dallas Office
> From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YObdy4loq_PlfnbIuQqODzLs7lDKeVnSFAM4r002PSYHDgNm6A7kniEe-5CND_fKC-gvaiXf851Ndh4Txg]khufumen@y...[/url
> sentence
> a Garmin 35-PC
> every second at
> transmits fine to
> (looks like an
> electronics
> caps are set up
> I think it must
> below.
> ' {$STAMP BS2p}
> MyByte VAR Byte
> PAUSE 250
> DEBUG CLS
> Main:
> DEBUG MyByte
> GOTO Main
> No_GPS_Data:
> DEBUG "No Data"
> GOTO Main
> SPSTR 65]
> days of
> right direction.
> Kind Regards,
> Eric
> ignored.
> Yahoo! Groups Links
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Hurray!! It works!!! I used the 22K resistor like you
suggested and its working fine.
Last question. If I want to send data to the GPS unit
(ie. to control what NMEA sentences it outputs) can I
transmit directly from the stamp or do I need to go
through a Max232? The GPS unit is about 6 feet away
from the BS2p40 stamp.
Thanks a ton.
Eric
> If you have an RS-232 level signal then you can feed
> it to the BASIC
> accidentally gets
> on several
> problems. I've
> model, but you
> -- Jon Williams
> -- Dallas Office
> From: Eric [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m9HweX9wRB1PoLIYyecCAnhFYBkjLvwDksmUGbQBZrVcA-gcbVHSAFItJncy3qwtHdQfgisCkkU]khufumen@y...[/url
> GPS sentence
> Jon,
> from
> Eric
> Remove
> > your MAX232 or
> baud
> > on the BS2p.
> > -- Jon Williams
> > -- Dallas Office
> > From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m9HweX9wRB1PoLIYyecCAnhFYBkjLvwDksmUGbQBZrVcA-gcbVHSAFItJncy3qwtHdQfgisCkkU]khufumen@y...[/url
> GPS
> > sentence
> from
> > a Garmin 35-PC
> > every second at
> > transmits fine to
> > (looks like an
> > electronics
> > caps are set up
> 12).
> > I think it must
> > below.
> > ' {$STAMP BS2p}
> > MyByte VAR Byte
> > PAUSE 250
> > DEBUG CLS
> > Main:
> > DEBUG MyByte
> > GOTO Main
> > No_GPS_Data:
> > DEBUG "No Data"
> > GOTO Main
> with:
> > SPSTR 65]
> > days of
> the
> > right direction.
> > Kind Regards,
> > Eric
> be
> > ignored.
> > Yahoo! Groups Links
> Text in the Subject
> Yahoo! Groups Links
> report SPAM to
> abuse@p....
> ignored.
> Yahoo! Groups Links
Stamp quite happily can recieve RS-232 signals.
The Stamp has internal clamping diodes which
prevent damage to the pins in this case.
It can't SEND this way, of course.
What Jon was saying is there is an 'Invert' option
in the baud-rate selector ($4000). With a MAX232,
you need to select 'Invert'. With a 22Kohm resistor,
you don't select 'Invert'. Or, vice-versa, I've
not yet seen a definitive answer to when you need
invert and when not.
However, when using "Pin 16", I ALWAYS use the
Invert option.
--- In basicstamps@yahoogroups.com, Eric <khufumen@y...> wrote:
> Jon,
> Eric
> > your MAX232 or
> > on the BS2p.
> > -- Jon Williams
> > -- Dallas Office
> > From: Eric Berg [noparse][[/noparse]mailto:khufumen@y...]
> > sentence
> > a Garmin 35-PC
> > every second at
> > transmits fine to
> > (looks like an
> > electronics
> > caps are set up
> > I think it must
> > below.
> > ' {$STAMP BS2p}
> > MyByte VAR Byte
> > PAUSE 250
> > DEBUG CLS
> > Main:
> > DEBUG MyByte
> > GOTO Main
> > No_GPS_Data:
> > DEBUG "No Data"
> > GOTO Main
> > SPSTR 65]
> > days of
> > right direction.
> > Kind Regards,
> > Eric
> > ignored.
> > Yahoo! Groups Links
short connections between the BASIC Stamp and the GPS unit you can get
away with not using the MAX232.
-- Jon Williams
-- Dallas Office
From: Eric [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t1MnbjuMuf3M8XRpUkgtse16kmRHmnhxZrnjrKNOLkFTHKInNkl2QS9FxlfptnMc5ytlHAs4WrchCA]khufumen@y...[/url
Sent: Tuesday, June 01, 2004 1:59 PM
Jon,
Thanks a ton.
Eric
> it to the BASIC
> on several
> problems. I've
> model, but you
> -- Jon Williams
> -- Dallas Office
> GPS sentence
> Jon,
> from
> Eric
> Remove
> > your MAX232 or
> baud
> > on the BS2p.
> > -- Jon Williams
> > -- Dallas Office
> > From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t1MnbjuMuf3M8XRpUkgtse16kmRHmnhxZrnjrKNOLkFTHKInNkl2QS9FxlfptnMc5ytlHAs4WrchCA]khufumen@y...[/url
> GPS
> > sentence
> from
> > a Garmin 35-PC
> > every second at
> > transmits fine to
> > (looks like an
> > electronics
> > caps are set up
> 12).
> > I think it must
> > below.
> > ' {$STAMP BS2p}
> > MyByte VAR Byte
> > PAUSE 250
> > DEBUG CLS
> > Main:
> > DEBUG MyByte
> > GOTO Main
> > No_GPS_Data:
> > DEBUG "No Data"
> > GOTO Main
> with:
> > SPSTR 65]
> > days of
> the
> > right direction.
> > Kind Regards,
> > Eric
The PC serial port sends & expects to receive all serial data inverted.
With the Stamp connected to the PC serial port through the MAX232 or
equivalent converter IC, the Stamp needs to send/receive in TRUE mode
because data is inverted when passing both directions through the MAX232
converter IC.
TTL in RS232 out
Stamp true serial out >
> max232 >
> inverted in to PC
TTL out RS232 in
Stamp true serial in <
< max232 <
< inverted out from PC
With the 22K series resistor method or "direct" connection between the
Stamp & PC serial port, you would use inverted mode due to the PC serial
port sending & expecting to receive all serial data inverted.
TTL out
Stamp inverted serial out to PC >
> inverted to PC serial in
RS232 in
Stamp inverted in from PC <
< inverted from PC to Stamp
22K
The 22K resistor limits current & helps protect the Stamp input pin from the
higher RS232 voltage levels, and, as Jon mentioned, in case you inadvertently
make the Stamp pin an output with the direct connection.
-Bruce
tech@r...
http://www.rentron.com
Have you done labs to prove this to yourself?
The only connection I've made successfully is
the:
SEROUT 16, $4000 + 84, [noparse][[/noparse]"HI",13]
Where I believe the '$4000' (Invert)is required.
Mind you, this is where the PC is putting
out what it puts out, and the BS2 is using
its own 'max232' equivalent.
"Inverted" here can be hard to define. The
RS232 signal definition is +12 to -12, with
'Mark' and 'Space' states. I'm glad you seem
so positive, though.
inverted.
mode
MAX232
> converter IC.
> TTL in RS232 out
> max232 >
inverted in to PC
> TTL out RS232 in
< max232 <
< inverted out
from PC
the
serial
> TTL out
> inverted to
PC serial in
> RS232 in
< inverted
from PC to Stamp
> 22K
from the
inadvertently
> Regards,
> -Bruce
> tech@r...
> ...The only connection I've made successfully is the:
> Where I believe the '$4000' (Invert)is required...
Actually, this is the one instance where the designated polarity is
of very little consequence. No matter how much you beg, cajole or
threaten your Stamp, it will only SEROUT inverted data when you
specify I/O 16, no matter the contents of baudmode's bit 14. For I/O
16, only the polarity of FPIN is affected by that bit's value. Try
it for yourself:
SEROUT 16, 84, [noparse][[/noparse]"HI",13]
Steve
Yes. You can easily test idle serial logic states with your Stamp
something like this;
Loop:
HIGH 1 ' Take pin 1 high
PAUSE 2000 ' Wait a bit
SEROUT 1, 16780, [noparse][[/noparse]"Hello"] ' Send the greeting.
' Place a logic probe on pin 1 and see what logic state
' pin 1 stays in when program flow gets to the Here routine
Here: ' Blink an LED on pin 15
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
GOTO Here
Now change the baud mode from inverted (16780) to true (396), and set
pin 1 low before entering the serout line something like this;
Loop:
LOW 1 ' Take pin 1 low
Here:
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
GOTO Here
This shows you how the Stamp assumes you'll be using the pin for more
serial output, and leaves it at the appropriate idle logic after the SEROUT
commands using both true or inverted modes.
If you refer the a MAX232 internal block diagram you'll see how this logic
works. They normally include pull-up & pull-down resistors to hold both
sides in the idle states should the device be disconnected on not powered
up. http://www.rentron.com/Files/bMAX232.gif
> the: SEROUT 16, $4000 + 84, [noparse][[/noparse]"HI",13]
Using the Stamp modules "built-in" serial programming pin is different
since the Stamp module includes additional "onboard" circuitry for the
RS232 programming/debug connection. You can verify/view this in the
Stamp module schematic.
The original thread/problem used > > SERIN 0, 16884, 1500, etc, etc,
and was not using the Stamps built-in RS232 circuit.
Using the Stamps built-in RS232 circuit on pin 16, you can't change modes
between inverted or true. Only baud rates.
-Bruce
tech@r...
Reynolds Electronics
wrote:
> If you have an RS-232 level signal then you can feed it to the
BASIC
gets
I've
had any
Jon, do you (or anyone) know if the Garmin Geko 101 can be
interfaced to the BS2? All this talk about interfacing GPS to BS2,
and I see Radio Shack has the Garmin Geko 101 for sale for around
$84.00.
Knight Designs
-- Jon Williams
-- Dallas Office
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nVqPmumqOgqP5C4r1ALQ9oMZfrxh-SFMhu9DJN2TtcH-tsqseVO8sE5Si4auq6gYKopVuqFGPCqs7u43TOSx90yN]knight_designs@y...[/url
Sent: Wednesday, June 02, 2004 6:55 PM
Subject: [noparse][[/noparse]basicstamps] Re: At wits end reading NMEA GPS sentence
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
BASIC
gets
I've
had any
$84.00.
Knight Designs
Yahoo! Groups Links
abuse@p....
wrote:
> Yes, I have also connected a Geko unit to the BS2p. No problem.
> -- Jon Williams
> -- Dallas Office
Thanks Jon! Perhaps someone will get me one for Father's Day? ;-)
Knight Designs
