P w m
Hi everyone,
is that possible to do a kind a PWM with a 555 controled by a BS2 is
anyone did before. I want to do a motor speed controler.
Regards
Chris
Regards
Chris
filtered PWM output to control it.
-- Jon Williams
-- Dallas Office
From: vermettechristian [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=izD--Gk2DjPenLyX9mTsdX0aWUGsrpkCPktXpk223sQw6BUlwkt4fR_M7pTUIuAUokJ5tIx1evYIj6n4QeSYU14zeGSYKA]christian_vermette@v...[/url
Sent: Tuesday, June 01, 2004 11:32 AM
Subject: [noparse][[/noparse]basicstamps] P W M
Hi everyone,
Regards
Chris
<christian_vermette@v...> wrote:
> Hi everyone,
> Regards
> Chris
What benifit would you get with a 555 ?
It seems the PWM in not a perfect duty cycle, but makes the full count
come out right over time. For motor control, the more accurate the
pulse stream the higher efficency you will get in the motor.
I may have answered my own question. you send a varying signal to
the 555 instead of a pot and that will adjust the more accurate 555
duty cycle....
Dave
> > Hi everyone,
> > Regards
> > Chris
>duty cycle....
>Dave
I was going to suggest a method that involves using two Op-Amps.
One generating a triangle wave, and the other acting as a comparator.
The Triangle wave feeds one leg of the comparator, while the other
leg of the comparator is fed PWM from the stamp. The Output of the
comparator is a 0% to 100% duty cycle.
When searching for a relatively simple circuit to generate a triangle
wave from an Op-Amp, I came across these excellent article which basically
describe what I had in mind...
http://www.cpemma.co.uk/throbber.html
http://www.cpemma.co.uk/pwm.html#classic
... have fun!
Beau Schwabe Mask Designer II National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Mail Stop GA1
