BS2 Stamp Defective? or what am I doing wrong
Hello,
I'm having trouble getting my stamp to run more than a few
instructions at a time and I'm hoping someone more knowledgable than
myself can lend me a hand.
Its a BS2 BOE board, everything appears to work fine as far as
detecting the stamp and running programs.
The problem is the program will terminate without completing all the
steps and sometimes output a strange character to the debugger. The
program in question is below.
'{$STAMP BS2}
Counter VAR Byte
Init:
DEBUG "INIT"
Main:
FOR Counter = 1 TO 10
DEBUG ? Counter
PAUSE 500
NEXT
DEBUG "MAIN FINISHED"
END
Three runs produced the following output to the debugger
Run#1
INITCounter = 1
Counter = 2
Counter = 3
Counter = 4
Run#2
INITCounter = 1
Counter = 2
Counter = 3
Counter = 4
Counter = 5
Counter = 6
Cou
'{$STAMP BS2}
Counter VAR Byte
Init:
DEBUG "INIT"
Main:
DEBUG ? Counter
PAUSE 500
NEXT
END
Run#1
INITCounter = 1
Counter = 2
Counter = 3
Counter = 4
Run#2
INITCounter = 1
Counter = 2
Counter = 3
Counter = 4
Counter = 5
Counter = 6
Cou
lyn913@y... writes:
> Main:
> DEBUG ? Counter
> PAUSE 500
> NEXT
> END
Change "END" to "goto main" and see what happens.
Sid Weaver
512K plug-in EEPROM.......
http://www.visualmuses.com/chipcircuit/index.html
-- Jon Williams
-- Dallas Office
From: lyn913 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=R-brwdNfi-DVirPoYiLc8AXr_U4FcK5FVzdAkmmVy8iWCOoEXJZrgZxiYp92lCROPZwMOv01]lyn913@y...[/url
Sent: Monday, May 31, 2004 1:18 AM
Subject: [noparse][[/noparse]basicstamps] BS2 Stamp Defective? or what am I doing wrong
Hello,
'{$STAMP BS2}
Counter VAR Byte
Init:
DEBUG "INIT"
Main:
DEBUG ? Counter
PAUSE 500
NEXT
END
Run#1
INITCounter = 1
Counter = 2
Counter = 3
Counter = 4
Run#2
INITCounter = 1
Counter = 2
Counter = 3
Counter = 4
Counter = 5
Counter = 6
Cou
insufficient power. What type of power supply are you using? If its a 9V
battery try replacing with an fresh 9V alkaline battery. the BS2 uses very
little power but certain instructions tend to pull peak current for very
brief periods. sometimes batteries and even cheap wall-warts just can't
keep up. Suggest using the DC adapter that came with your BOE board. It can
also be the length and type of your serial cable as well.
At 01:18 AM 5/31/2004, you wrote:
>Hello,
>'{$STAMP BS2}
>Counter VAR Byte
>Init:
>DEBUG "INIT"
>Main:
> DEBUG ? Counter
> PAUSE 500
> NEXT
> END
>Run#1
>INITCounter = 1
>Counter = 2
>Counter = 3
>Counter = 4
>Run#2
>INITCounter = 1
>Counter = 2
>Counter = 3
>Counter = 4
>Counter = 5
>Counter = 6
>Cou
