rotary encoder
Hi everyone
is there a way to serial out the count, except to use pin 8 to 15 on
this particular program. I need all the pin on my BS2 for input
signals, can I use the internal EEPROM I dont know I am beginer.
' {$stamp bs2}
'{$PORT COM1}
' Program to act as high speed quadrature counter
DIRH = %11111111
counter VAR Word
counter2 VAR Word
counter3 VAR Word
old VAR Nib
new VAR Nib
directn VAR Byte
' Channel a and b of encoder go on inputs 6 and 7 in this case.
quad:
counter = 125 'load a dummy value so can count up or down
new = INB & %0011 ' get initial condition
start:
old = new & %1100 ' remember initial setting
Again:
new = INB & %1100 ' get new reading
IF new = old THEN again
directn = new.BIT1 ^ old.BIT0 ' XOR left bit of new with right
bit of old to get direction
IF directn = 1 THEN CW ' jump here to increment
LOW 0 ' pin 0 turns led off if turning counter-
clockwise
counter = (counter+1) ' jump here to decrement
OUTH = counter
DEBUG DEC counter,CR
GOTO again
CW:
HIGH 0 ' pin 0 turns on led if turning clockwise
counter = (counter-1)
OUTH = counter 'turn on leds on pins 8 through 15 to watch
GOTO start
I want to serial out the count but not use pin 8 to 15, because I
need the pins for over travel, home position.... ect
Thank you for your help
' {$stamp bs2}
'{$PORT COM1}
DIRH = %11111111
counter VAR Word
counter2 VAR Word
counter3 VAR Word
old VAR Nib
new VAR Nib
directn VAR Byte
quad:
start:
Again:
clockwise
OUTH = counter
GOTO again
CW:
GOTO start
<christian_vermette@v...> wrote:
> Hi everyone
on
> ' {$stamp bs2}
> '{$PORT COM1}
> DIRH = %11111111
> counter VAR Word
> counter2 VAR Word
> counter3 VAR Word
> old VAR Nib
> new VAR Nib
> directn VAR Byte
> quad:
> start:
> Again:
counter-
> clockwise
> OUTH = counter
> GOTO again
> CW:
> GOTO start
Christian,
There's no requirement for outputs 8 - 15 to be used to show the
output count. I originally put it there for troubleshooting.
Just take out the two instances of "OUTH = counter" and use pins
8 - 15 as you need. To get the data out, change your DEBUG statement
to a SEROUT and send data out pin 16 ( the programming port ). That
way you have maximum pins for your application.
You can save one more pin by not using the direction indication
provided by pin 0.
Tom Sisk
