lightning sensor
Here is the problem I am trying to overcome...I guess I want to use
CdS photocells to detect a lightning bolt at max sensitivity. When
it is triggererd it will trigger my digital camera to take a
picture. Here is my real question should I use CdS Photocells or an
Infered detector?? Do I have To use The Rctime command? and How do I
get max sensitivity out of either sensor?
Thank you for your time,
Mark
Mark
Every once in a while there's a question I can actually help on, and yours
happens to be it this time! I have a fair amount of experience phtographing
lightening.
If you wait to trigger the camera until the light from the Lightening Bolt
in seen it is too late. The lightening strike is already (in most cases)
over.
The shutter delay on most digital cameras adds to this problem.
There are a couple sensors that can be used to detect the strike before it
takes place. If I remember correctly one is a "capacitance" sensor. The
other is based on radio waves. Lightening generates RF interference which
can be detected. Try listening to your am radio during a lightening storm
some time.
Also, it is possible ( with limited results ) to use phototransistors to
detect the light from the strike, open the shutter for a given amount of
time, and hope that during that during the additional time another strike
takes place. Which is often the case.
There are a couple manufacturers that make lightening strike sensors for
photography. IF you'd like I can try to look them up for you. They are
mostly advertised in "Outdoor Photography" magazines.
I, for the msot part, still do my lightening photography the old fashioned
DANGEROUS way. Point the camera in the direction of the majority of
strikes, ....
Cover the front of the lens with my hat, open the shutter using the bulb
setting, remove the hat, and wait several seconds for a few strikes to take
place, replace the hat, repeat a couple of times, advance film and repeat.
I really prefer to photograph out the window of the car tripod mounted out
side window, me inside. This way if lightening strikes too close, I may
lose a camera, but I don't get fried, due to the "skinning" effect caused by
the car.
If you have any questions, you may feel free to e-mailme offlist at
Info@C...
Sorry for being so verbose. Hope I helped.
Rus
From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KH7pU9FZXD9LQKYOE5ittEtP8fIFXZPOCAKBBfgqv42DVTx-_OJFiI8_Odir_WHFFE3iEboBuLNA8qldGN4]uebermenchens@a...[/url
Sent: Wednesday, May 26, 2004 7:12 PM
Subject: [noparse][[/noparse]basicstamps] lightning sensor
Mark
Yahoo! Groups Links
Sometimes you can bias a detector with some dc to get it close to the trip
point and get some sensitivity, but it takes diddling with.
From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eriM3Mq24Tz3VSZosvUq3lOkPJDhC0jxrlkqEIaw0yqYJGswWV4L3Q01VptXh0FiHRWK_NjRL72dIcAA]uebermenchens@a...[/url
Sent: Wednesday, May 26, 2004 8:12 PM
Mark
Yahoo! Groups Links
lot of science. I used to work in the golf irrigation business and
spent a lot of time with a company called Global Atmospherics. GA is
the company that built the lightning detection network that is used by
the military, FAA, NASA, etc.
Here's the deal: Lightning has very specific optical and electromagnetic
"fingerprints" that are used by the detectors to qualify the event as a
strike. The detectors that we worked with in the golf industry could
give rough distance as well (the big network uses multi-sensor
triangulation to pinpoint the strike).
A CdS photocell is very slow to react, and the actual light reaching the
cell from a strike is so small that you will have an incredibly
difficult time discerning it from background noise. Remember, human
eyes are far more sensitive to light than electronic devices.
Most "amateur" lightning detectors are built around a detuned AM radio
circuit. Since the lightning pulse contains a lot of broadband RF, a
noise pulse will blast out of the radio circuit during a strike.
Interestingly, the smoke detector in my apartment sometimes chirps when
lighting strikes nearby.
-- Jon Williams
-- Dallas Office
From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bXBHOgXnZT3M1BSYxRtSyxVjUYwq-Vp4WuTsUiFMfZNOmEIdnRCPWpH9nT17q9-LJPUW8p9e-kBj1syO]uebermenchens@a...[/url
Mark
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
an
I
> Mark
Reading some of the posts, what strikes me as a way I would considder
is to put a small motor on a seperate stand to eleminate vibration.
Add a rotating thing, like a hat on the motor so as to keep a very
black object in front of the camera when opening and closing the
shutter.
Then,
open shutter
rotate hat (tip unbrella?)
watch light sensor and when some level is reached, rotate hat
close shutter
advance film,
repeat.
This would all you a mecanized method of photographing lightning, but
still relies on random pointing of the camera.
Now your time lapse would be set for some light threshold so a
lightning bolt would turn your shot OFF. More film though.....
You could use an umbrella instead of a hat. Tipping or rotating
would work.
Dave
Here is a site that may help:
http://homepage.mac.com/tbitson/weather/bslam/index.html
I built one, it works well, although I don't get much lightning where I
live. You might be able to adapt this to what you wantr to do.
Jonathan
www.madlabs.info
Sent: Wednesday, May 26, 2004 10:08 PM
Subject: RE: [noparse][[/noparse]basicstamps] lightning sensor
> Mark,
phtographing
> lightening.
> over.
> some time.
> strikes, ....
take
out
by
> the car.
> Info@C...
> Rus
> From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EqnPcz34VgV3GCyxVz2MJztO4ngOIgIKbfS9N1PMbKybQ2IgJgfPdGi5-YvZ9sB9Jc_SWKW4zEQSFCdlag]uebermenchens@a...[/url
> Mark
> Yahoo! Groups Links
> Yahoo! Groups Links
notoriously slow responders.
Dov
From: Grover Richardson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E7WsW0AMcTO4ZzDn8IqwTNLgjC_s8cnej9MEV5M5xLcsrOFEyGuTuZsHMvT4Oz7hxMi0gxFuXIxk_cjNypV3it9tL_j8rB5-]grover.richardson@g...[/url
Sent: Thursday, May 27, 2004 2:22 PM
CdS cells, as I remember are seriously slow for what you want to do.
trip point and get some sensitivity, but it takes diddling with.
From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DnnjivA-Y8EtNqVburfRpDXjhRk0Qa_xW-kMFU-ddzzza__vpDrSBuoN3hkfDay2JcQ9mqPfef7ODoE]uebermenchens@a...[/url
Mark
Yahoo! Groups Links
Yahoo! Groups Links
I work for Environment Canada and we use GAI (now Vaisala) equipment all
over the country for lightning detection.
http://www.weatheroffice.ec.gc.ca/lightning/index_e.html this is a quick
link to EC's lightning strike page (does show some US states).
We use two sensors....one is an Lpatts IV and mainly gives indication of a
strike and a power reading associated with that. These sensors are
sensitive enough that they can detect strikes hundreds of miles away....so
by this then can triangulate it's rough strike point. This sensor uses a
6foot dipole antenna (Fibreglass).
The 2nd sensor we use is their Impact sensor. This sensor does the strike
detection by way of using an electromagnetic cage detector (I'm struggling
for the right words to describe it). But basically it has 4 bars (brass I
want to say...probalby not) as the pulse from the strike hit sthe
senor.....these bars will indicate a direction of strike by way of
differeing power levels per bar. This sensor helps pinpoint the strike even
better.
I think the network resolution is somewhere less than 10km. All these
sensors are clocked in with GPS antenna's that keep time and their own
location (which doesn't change for the most part).
Cool devices....
Since I'm on the topic....I was at my boss's place out in the country one
time....and his phone would ring once in a while (old bell ringer). But it
would only ring once and nobody ever moved to get it.
I asked about it and he pointed out that the ring coincides with the
thunder....they never pick up the phone on the first ring!!
Incidentally...on that same visit...lightning hit a fence post about 50yards
away....like a shotgun blast beside your head! We all hit the ground!!
I got off topic on that one!! haha
BTW here's the URL for the vaisala/GAI site http://www.lightningstorm.com/
Steve
Sent: Thursday, May 27, 2004 9:23 AM
> Lightning is a very tricky phenomenon -- and accurate detection takes a
> -- Jon Williams
> -- Dallas Office
> From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nf4taRz5AZMnoGc5abY3Hw1w2U6sQfw_j8rFGMsZqtxuhXXX4IoG68uMCZSaMVChLVQzi2hMcVcHBYKE]uebermenchens@a...[/url
> Mark
> Yahoo! Groups Links
> abuse@p....
> Yahoo! Groups Links
aim the camera straight up at a dome mirror/lens and you might get some cool
lightning shots that way!
What you need is a neutron detector....detects the flow and the impending
strike then does your mechanic wonders....problem being....you're most
likely a potential strike target if the detector detects! [noparse];)[/noparse]
Sent: Thursday, May 27, 2004 9:52 AM
Subject: [noparse][[/noparse]basicstamps] Re: lightning sensor
> --- In basicstamps@yahoogroups.com, "uebermenchens"
> an
> I
> > Mark
> shutter.
> Then,
> open shutter
> close shutter
> advance film,
> repeat.
> would work.
> Dave
> Yahoo! Groups Links
(mounted vertically) that could see the electromagnetic and IR pulses
from a lightning strike. It could tell direction (being a single point
sensor), but could distinguish between cloud-to-cloud and
cloud-to-ground (the stuff that causes problems), as well as low res
ranging on the CTG strikes.
I live very near a company that rents large earth-moving equipment and
that "yard" seems to be a big lightning rod -- I've never been as close
as 50' from a strike, but even at 100 yards the sound is earth-shaking,
and shakes everything in my apartment.
-- Jon Williams
-- Dallas Office
From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jEtrr6ncHBKtLExgTL8pGZSOzP6TXsw0q4Y8V7eEWFkZAaJc1JPESx1r61jK3MPeur9SwCTm1zfbRMGr]steve.brady@r...[/url
Sent: Thursday, May 27, 2004 4:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] lightning sensor
Hi Jon,
quick link to EC's lightning strike page (does show some US states).
a strike and a power reading associated with that. These sensors are
away....so by this then can triangulate it's rough strike point. This
sensor uses a 6foot dipole antenna (Fibreglass).
strike detection by way of using an electromagnetic cage detector (I'm
struggling for the right words to describe it). But basically it has 4
bars (brass I want to say...probalby not) as the pulse from the strike
hit sthe senor.....these bars will indicate a direction of strike by way
of differeing power levels per bar. This sensor helps pinpoint the
strike even better.
Cool devices....
one time....and his phone would ring once in a while (old bell ringer).
But it would only ring once and nobody ever moved to get it. I asked
50yards away....like a shotgun blast beside your head! We all hit the
ground!!
Steve
> a lot of science. I used to work in the golf irrigation business and
> electromagnetic "fingerprints" that are used by the detectors to
> qualify the event as a strike. The detectors that we worked with in
> the golf industry could give rough distance as well (the big network
> uses multi-sensor triangulation to pinpoint the strike).
> the cell from a strike is so small that you will have an incredibly
> when lighting strikes nearby.
> -- Jon Williams
> -- Dallas Office
> From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=knbLp2G00xTfRqjfYifKqTKFj7nLzWk8d0q9pEm7DgESnblJINSrnvEaTobx4u5hMDNyg4cPuB_zIhI]uebermenchens@a...[/url
> CdS photocells to detect a lightning bolt at max sensitivity. When it
> is triggererd it will trigger my digital camera to take a picture.
> Here is my real question should I use CdS Photocells or an Infered
> detector?? Do I have To use The Rctime command? and How do I get max
> Mark
it the lightning is past by the time you can detect it. My idea would
be to set up the camera to just keep taking pictures at suitable
intervals and use the control circuitry, stamp or whatever, to decide
that a lightning strike occurred during the last exposure and them
record this so you can view that picture number later. Then you can
automatically stop or continue taking pictures or not if you want more
views with lightning. If you could somehow automatically decide after
each exposure that lightning had occurred during the exposure and erase
that image if it did not have lightning, or save it if it did, you could
fill your entire memory card with lightning strikes! Perhaps you could
achieve this with IR commands via the Stamp. The nice thing about
digital is no film, no waste!
I agree with others that a CdS photoreceptor does not seem like
the best choice. -Al Hill
> Mark
> from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
> Yahoo! Groups Links
Dave
Al Hill <alhill@s...> wrote:
Mark- I haven't read every last post but the main problem is as I see
> Mark
> Yahoo! Groups Links
Yahoo! Groups Links
Do you Yahoo!?
Friends. Fun. Try the all-new Yahoo! Messenger
I suppose that a protocol (unknown for me) is used. If you find it, let me know.
ECO
Sent: Friday, May 28, 2004 3:33 PM
> Forgive me for barging in here. I have read these posts with great interest, but I can't help but wonder: what are you going to use for a shutter release? I have been looking into this, but I haven't even found a digital camera with an electronic shutter release.
port, adjust the lens and lots of other features I never needed.
Larry Gaminde
Sent: Friday, May 28, 2004 6:33 AM
> Dave
> > Mark
> > Yahoo! Groups Links
> Yahoo! Groups Links
> Do you Yahoo!?
> Yahoo! Groups Links
cable release, it is fairly simple to connect a solenoid to the cable to
make an electrically triggered mechanical shutter release.
However, the best method of getting lightning shots by night has been proven
to be:
Use a slow speed film such as 25 speed tech pan for black&white or ektar 25
for color.
Open the shutter for a few minutes, if a lightning strike occurs close the
shutter, advance film, re-open shutter.
If no strike after a few minutes, close shutter and advance film, then
re-open shutter.
Repeat this process until you are out of film or the storm has passed.
Digital cameras just plain do not work well for this, but if you must try to
catch a lightning strike digitally, the best method would probably be to use
a camera capable of digital video, then you could go back and select the
frame that looked best.
$.02 - KF4HAZ - Lonnie
> Dave
> > Mark
Maybe a photo slave? These mount on remote slave flash units for photography,
and are used to fire a slave flash when the primary flash is tripped. One of these
might be fast enough to fire your camera when lightning strikes. They are fast
enough to fire slave flashes in time to catch the camera shutter open.
You can get them at most camera stores. I think I paid around $6.00 ea for the ones
I have.
-Bruce
tech@r...
http://www.rentron.com
My thing is movie making, and since switching from film cameras to
video, I've lots the abililty to do nice time-lapse stuff (yes, some
video cameras have this feature, but it's limited and puts a lot of wear
on the video heads). With your camera and a BASIC Stamp, I could make a
cool time-lapse setup.
-- Jon Williams
-- Dallas Office
From: Stamps [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JQE_CCZOjJJJBvU0V_xEUGl-Mdrr3PO9tunOmW0nJ_4NnrYq4SvHpLJIePAyWMIzMkZMdaTzL7_X7a7cUrsTQvJ4vzPpxQ]stamps@c...[/url
Sent: Friday, May 28, 2004 8:52 AM
I have a RS232 digital camera it is able to take pictures over the
download port, adjust the lens and lots of other features I never
needed.
Larry Gaminde
> Dave
> erase that image if it did not have lightning, or save it if it did,
> you could fill your entire memory card with lightning strikes! Perhaps
> you could achieve this with IR commands via the Stamp. The nice thing
> about digital is no film, no waste! I agree with others that a CdS
> photoreceptor does not seem like the best choice. -Al Hill
> > Mark
> > and
> > Yahoo! Groups Links
> and
> Yahoo! Groups Links
> Do you Yahoo!?
> and
> Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
Digital Rebel as a birthday gift. This camera has electronic shutter
release; film speeds of 100-1600 ASA and can take 4 hi-res (6 mega pixel
images) per second.
I was able to get several lightening strikes on "film" by setting the
exposure to 10 seconds, 15 seconds and 30 seconds at various film speeds. To
the naked eye, the sky itself was not visible until a lightening strike, but
the sky and surrounding trees were very visible in the images the camera
captured.
Jeff
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vPvfUKSnxhGp0U8O3nhebh0IT6ZyFKrI8h4jNzN5SDHRCd-D-ClZEeqlSasaQ1P09nLHupcWBJ53GW81lt8YwcfvrVM]techsupport@f...[/url
Sent: Friday, May 28, 2004 9:54 AM
With Single Lens Reflex film cameras there is an attachment point for a
to be:
for color.
re-open shutter.
I got it for use with stamps only, and time laps pictures would work
perfectly.
They sell them as refurbished units for around $100.00 with download
software
Larry Gaminde
Sent: Friday, May 28, 2004 8:10 AM
> May I ask what kind of camera it is and what the pixel resolution is?
> -- Jon Williams
> -- Dallas Office
> From: Stamps [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6-NJ7vStVbvFChKXlt1QYL4CcFJyWP-uKna77ezFZNuGiPLunkzt0keiDkbnEQKl8Z7aHCAsQGsqydHLEbFYSBYTFanTtg]stamps@c...[/url
> needed.
> Larry Gaminde
> From: "David Anderson" <dersonquilter2@y...>
> > Dave
> > > Mark
> > > and
> > > Yahoo! Groups Links
> > and
> > Yahoo! Groups Links
> > Do you Yahoo!?
> > and
> > Yahoo! Groups Links
> Yahoo! Groups Links
> abuse@p....
> Yahoo! Groups Links
Larry Gaminde
> -- Jon Williams
> -- Dallas Office
> From: Stamps [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=73Da7xAu374IRF6aF_D0qsde8mB6nbn2HW_zqnrA2MABmded3MF-780Iqnis3OuVhJQW6YvwnOt341ReqMRReG-saEhH]stamps@c...[/url
> needed.
> Larry Gaminde
> > Dave
> > > Mark
> > > and
> > > Yahoo! Groups Links
> > and
> > Yahoo! Groups Links
> > Do you Yahoo!?
> > and
> > Yahoo! Groups Links
> Yahoo! Groups Links
> abuse@p....
> Yahoo! Groups Links
On my digital camera, when I take a pic, it then shows me what I've taken
and then asks me if I want to keep it.
I don't know what kind of control you have over your comm cable, but if you
constantly took pics with a slow shutter then you could have the stamp say
whether to save it or not depending on whether it detected a flash....slow
process and you'd probably miss a lot of strikes....but hey....
Sent: Friday, May 28, 2004 10:17 AM
photography,
of these
fast
the ones
> I have.
> Regards,
> -Bruce
> tech@r...
> Yahoo! Groups Links
build and play with this.
Thanks!
Shawn Lowe
> Jonathan
> www.madlabs.info
