running multiple relay''s from BS-1
In a message dated 5/26/2004 12:08:43 PM Eastern Daylight Time,
haksaw@r... writes:
> If possible can someone please set me straight on how I should
> controll 4 @ 24VDC (or 12VDC I have ideas for both) air valves from
> the BS-1. and if possible a schmatic or visual diagram of how to
> connect these things would be very helpfull for me to understand this
The simplest way is to use a 74HC595 shift register to drive a ULN2003
Darlington array. The 595 takes 3 I/O ports of the Stamp and lets you control the 7
channels of the ULN2003. Sending a high to a Darlington input turns that
channel on, taking the output to ground, which completes the circuit for a load
connected to the output.
Sid Weaver
512K plug-in EEPROM.......
http://www.visualmuses.com/chipcircuit/index.html
haksaw@r... writes:
Sid Weaver
