Parallax - Floating Point Coprocessor
Hello Parallax friends,
I want to introduce you to the Micromega um-FPU (Floating Point
Coprocessor). The uM-FPU is a 32-bit floating point coprocessor that
can be easily interfaced with the BASIC Stamp(r) microcontroller (BS2,
BS2e, BS2sx, BS2p24, BS2p40 or BS2pe) or Javelin Stamp microcontroller
to provide support for 32-bit IEEE 754 floating point operations and
long integer operations. For either microcontroller, the set up only
requires 2 pins.
The direct link below contains the complete description and
documentation or just click on the link at www.parallax.com
<http://www.parallax.com/>
For complete details check out the .pdf manuals and source code files
which are very thorough and well written.
http://www.parallax.com/detail.asp?product_id=604-00030a
Have a great day.
Best Regards,
Erik Wood
ewood@p...
(916) 624-8333 x106
www.parallax.com
requires 2 pins.
Have a great day.
Best Regards,
Erik Wood
ewood@p...
(916) 624-8333 x106
www.parallax.com
> Coprocessor).
In the <umfpujavelinstamp.pdf> document on page 5:
// value = |value|
value.negate();
This should probably be:
// value = |value|
value.abs();
This happens again on page 9 for integers.
Looks kool otherwise. Just wish Java had operation overloading so I could
use algebraic notation instead of having to call all those methods. (minor
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)</umfpujavelinstamp.pdf>
