sensing 5 volts from an infrared sensor ( 0 or 5 volts DC ) (separate power sup
The schematic is easy . But do you know about the
Basic Stamp command for this ?
The sensor has +5, gnd, signal.
I 'll try to join GNDs but I am not sure about the
command .
The sensor gives me 0(off) or +5(on) .
(it is a simple sensor)
Any suggestion please ?
--- smartdim@a... wrote:
> Daryl,
> Without seeing a schematic this solution is not 100%
> guaranteed to work, but
> you should be able to make it work by simply
> connecting the grounds together
> of the separate power supplies.
> Thanks,
> The problem I have is that the sensor has a separate
> power supply.
> I have used an infrared sensor from parallax powered
> by the basic stamp VDD and now the sensor is powered
> by an external power supply.
> Is it necesary a kind of optocouple or I need the
> basic stamp only ?
> Thanks, Daryl
> [noparse][[/noparse]Non-text portions of this message have been
> removed]
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Domains – Claim yours for only $14.70/year
http://smallbusiness.promotions.yahoo.com/offer
command .
> Daryl,
> Thanks,
> power supply.
> basic stamp only ?
> Thanks, Daryl
> removed]
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
