Can''t Identify Stamp
Disconnect power and remove the BASIC Stamp module from the socket.
Inspect the pins; you may have bent one of the programming connection
pins. If so, carefully straighten the pin(s) and put back into the
socket making sure that all pins are seated.
-- Jon Williams
-- Dallas Office
From: xbww007 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z_QB6ehvnmoNCoAB6WflVy1vNdFiqfbKAu-4d5QSM5kb7yegVxC-qMwDH63Uh3y3CuP_VCJIfeBqRyRHQwR9J0ILQuqq]bwarlick@s...[/url
Sent: Friday, May 21, 2004 11:23 PM
Subject: [noparse][[/noparse]basicstamps] Can't Identify Stamp
Just received my first Basic Stamp & Board of Education. The
Identify menu shows Loop Back = Yes Echo = Yes. It does not
identify the chip.
Running Windows XP on a desktop PC (e-machine).
Power LED is on.
Tried a 9v battery as well as an ac adapter - doesn't work. Tried a
different computer (win2k) - doesn't work. Tried a different serial
cable - doesn't work. Removed chip - reseated it - doesn't work. Removed
chip again - reseated it - doesn-t work. Tried changing FIFO setting on
serial port - doesn't work.
I give up. Guess it's DOA?
Any ideas?
-- Jon Williams
-- Dallas Office
identify the chip.
Power LED is on.
Any ideas?
