uln2803
Is there anything smaller than the 2803 that can handle at least 25mA per
output? I need to drive 12 - 16 LEDs that are 20mA each in as small of a
total form factor as possible.
Eric
Eric
If you can get away with a little less current, 74hc595 will drive 8 LEDs
at 10 to 15 mA each. They also have the added advantage of allowing you to
drive as many LEDs as you want from only 3 pins.
If you need more current, the TI TPIC6595 OR TPIC6C595 are good for 200mA
or 100mA respectively. Same 3 wire interface as the 74hc595.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 20 years of Engineering Innovation (1984 - 2004)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
25mA per
of a
> Thanks,
> Eric
use SOP transistors. they are slighly larger than the pads they
connect to.
But, for 16, you might be better off with a MCP23016 it is available
in TSSOP and QFN packages for slightly small size.
Dave
