Connecting an IPAQ with a BS2P
Hi everybody,
I'm searching for a technical website who provides information about
connecting an IPAQ (my ipaq is a 3850) to a Basic stamp. I want to use the
BS2P(24pins)for reading information in (pressures, temperatures) and sending
that information to my IPAQ. It is also a output device wich will switch
solid states on and off.
I'm creating a visual basic program wich will take care of all the commands
and will also "drive" the basic stamp to send the information continually to
the IPAQ.
Could someone help me with my project?
Sorry for my terrible english.
Kindly regards
Tim Christiaen
A Belgian ICT student
the IPAQ.
Kindly regards
Tim Christiaen
use the BS2P(24pins)for reading information in (pressures,
temperatures) and sending that information to my IPAQ. It is also a
output device wich will switch solid states on and off.
commands and will also "drive" the basic stamp to send the
information continually to the IPAQ.
Kindly regards
Tim Christiaen
to connect stamp and iPaq
¡§TLD-NV¡¨©ó 2004 ¦~ 5 ¤ë 20 ¤é¡A¶g¥| 04:29PM ´£¨ì¡G
> Hi everybody,
> the
> sending
> switch
> commands
> continually to
> the IPAQ.
> Kindly regards
> Tim Christiaen
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> Yahoo! Groups Links
slimboyfatboyslim
http://www.slimboyfatboyslim.org
http://www.parallax.com/dl/docs/prod/comm/eb500.pdf
though hugely expensive (ok, tht's a relative judgement) [noparse]:([/noparse]
Andy
--- In basicstamps@yahoogroups.com, Annie Wan <o_wan@y...> wrote:
> did you try embedded bluetooth module? seems this is the only
solution
> > Hi everybody,
about
to use
> > the
and
> > sending
> > switch
the
> > commands
> > continually to
> > the IPAQ.
> > Kindly regards
> > Tim Christiaen
Subject
> > Yahoo! Groups Links
> slimboyfatboyslim
makers make a USB>rs232 or even a CF>rs232 interface. If you can find
a serial port (or a virtual serial port via one of those CF or USB
interfaces), you can find some inexpensive rs232 monitoring/data
logging software for the iPaq.....will save you some time coding your
own. www.5dtool.com has one and it's free.
However, if you do want to write your own terminal/data logging
program, try "Visual Programmers Guide to Serial Communications" by
Dick Grier. There is some good info in there for coding rs232 comm
for pocketPc's.
If you cant come up with rs232, the Bluetooth solution already
mentioned is probably the most elegant and expensive. Or you can try
IrDa. IMO infrared is a pain because of the alignment/proximity
issues.
Good luck!
--- In basicstamps@yahoogroups.com, "Andy Powell" <andy@h...> wrote:
> Yup, I tend to agree :
> Andy
> solution
> > > Hi everybody,
> about
> to use
> > > the
temperatures)
> and
> > > sending
will
> > > switch
> the
> > > commands
> > > continually to
> > > the IPAQ.
> > > Kindly regards
> > > Tim Christiaen
> Subject
> > > Yahoo! Groups Links
> > slimboyfatboyslim
http://www.boxwave.com/products/minisync/ms_ipaq_3839.htm
--- In basicstamps@yahoogroups.com, "Juan" <jpreston12@y...> wrote:
> Doesnt the iPaq have a serial port? Or perhaps one of the PDA cable
find
your
