Modify serial data flow from PC to Printer
Hi all, I need to interrupt the data sent from a PC to a printer by a
serial interface. there are certain characters when detected should
change to another character such as when ever a "Q" and "W" are
detected, the output will print a "2" and "3".
In other words: whenever the ASCII code for a Q and W is detected, it
will change them to the codes for the 2 and 3 and let the other codes
pass to the printer unchanged. I think it might take a long time to
check each character as it passes through the stamp but that would
not be a problem.
The number of lines sent to the printer is between 4 lines, if that
might help.
Keep up the good work....
Thanks very much,
Basil
not be a problem.
might help.
Thanks very much,
Basil
a
it
codes
> not be a problem.
that
> might help.
> Thanks very much,
> Basil
Basil,
What you're asking to do is not too complicated but, you are
correct to consider the speed issue. I've done it at 9600 baud with a
BS2sx but was handling something like 20 bytes at a time.
When you say 4 lines, do you mean 4 lines of 80 chars each? Also
what speed are you trying to run at. Slower is better!
The procedure is to grab a chunk of data and process each
character but not waste too much time if the character is not
required to change. Then spit the character out to the printer. The
LOOKDOWN and LOOKUP commands can be helpful.
Tom Sisk
