Stamp not responsive
I have the Boe-Bot kit and my stamp no longer responds to the BASIC
Stamp Editor. The board currently just loops the last program I
uploaded to it. When I go to upload a new program I recieve the "No
Basic Stamps Found" , when I attempt to run the Identify feature it
tests "yes" on loop and echo but no longer provides stamp info. I
was advised that a low battery issue could be the cause so I
switched out the batteries but to no success. Any help would be
greatly appreicated.
ago), and it's nothing to do with battery power, as I have seen it when
working off a mains powered supply.
Evidence suggests that: it is something to do with the relative order in
which
(a) The Stamp Editor app is started
(b) The BS is connected to the serial port
(c) The BS is powered
I have generally found that some combination in some order of
(a) Power-cycling the BS
(b) Switching to another serial port
will restore communications. This is annoying, and it would be good to hear
from Parallax whether this is a known issue (I have never had it happen with
a Javelin, but then again, the Javelin IDE is very different to the Stamp
Editor).
sentto-1327227-43911-1085009384-j.porter=computer.org@r...
om
[noparse][[/noparse]mailto:sentto-1327227-43911-1085009384-j.porter=computer.org@r...
.yahoo.com] On Behalf Of carl689
Sent: 19 May 2004 19:06
Subject: [noparse][[/noparse]basicstamps] Stamp not responsive
Yahoo! Groups Links
communication between my computer and the stamp.. it just stays
there looping... eh.. I tried what you mentioned below but to no
success
--- In basicstamps@yahoogroups.com, "Julian Porter" <j.porter@c...>
wrote:
> I've had that problem quite frequently (in fact, it happened about
an hour
when
order in
> which
good to hear
happen with
the Stamp
> Editor).
> From:
> om
BASIC
the "No
it
Subject and
> Yahoo! Groups Links
if anyone else is getting the error "[noparse][[/noparse]Java Error] TheRoom.java(0): Error:
Type java/lang/Double was not found" out of the Java IDE. I'm sure I'm not
trying to use any floating point math...
No response from Parallax support.
>Is there a yahoo group for the Javelin? I didn't see one, and I'm wondering
Here is the Yahoo Group for Javelin support:
http://groups.yahoo.com/group/javelinstamp
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
