Hyper Clear
A while back someone posted the command top clear the screen in
Hyperterminal. I had it but I lost it. Does anyone remember that command?
Sid Weaver
Sid Weaver
tracy@e... writes:
> Control+L (decimal 12)
> -- maybe.
That works just fine, Tracy. Thanks.
Sid
>Thanks
>Sid Weaver
-- maybe.
Note that HTPE has the capability to emulate several different
terminals. By default it comes up in ANSI emulation. You can google
that and find all the control codes available. It also can emulate
VT100 etc etc., which you choose in the "Emulation" drop box under
file/properties/setting, and that is stored with the connection
profile.
If you choose TTY as the terminal emulation, it will no longer
respond to most of those control codes except LF and CR and maybe a
few others.
-- regards,
Tracy
http://www.fh-jena.de/~gmueller/Kurs_halle/esc_vt100.html
> >Thanks
> >Sid Weaver
> -- maybe.
> profile.
> few others.
> -- regards,
> Tracy
> from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
> Yahoo! Groups Links
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
