Inconsistant serial numbers
Greetings fellow stamp enthusiasts,
I recently bought some DS2401 Silicon Serial Numbers and I am using
a BS2p24to read them. I am getting some wierd results. Half the
DS2401s respond to the [noparse][[/noparse]$33] Read ROM command with what appears to
be the proper serial numbers starting with family code 01. The
balance of the DS2401s respond with serial numbers starting with a
family code 03 and seem to yield varing serial numbers on subsequent
reads. However, all the DS2401s respond consistantly with what
appear to be good serial numbers if I use the [noparse][[/noparse]$f0] Search ROM
command. Would any one be willing to hazard a guess at what is
wrong here?
Thanks for your help in advance.
Numbatboy2004
wrong here?
Numbatboy2004
Are all of these on the same chain? if so how far apart?
Did you put a 4.7K pull-up resistor on the data line? You only need 1
pull-up. Doesn't matter how many devices you have connected together.
When you issue the "Read ROM" command ($33) are you storing the 64 bit
serial number in a 8 byte array? for example: OWIN data, 0, [noparse][[/noparse]STR
Rom_Serial_Num\8]
These are picky to power supply noise. I've had good luck with putting a
.1uF filter capacitor on the Vcc-gnd close to the device as possible. Use a
1uF cap if you have more than 16 devices on your network. another
possibility is perhaps the others are simply gone bad.
>wrong here?
>Numbatboy2004
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
