input decimal numbers to bs2
In a message dated 5/15/2004 6:37:16 PM Eastern Daylight Time,
grivacoba@y... writes:
> Please let me know what code to use to have two switches to insert
> decimal numbers to stamp2. One of the switches to increase the
> number and the other to decrese it, once you have the number you
> want then load it to stamp2 into a variable, probably with a thirth
> switch or pressing the two swithces at the same time, or just after
> a time interval.
I'm not sure what you are trying to do but you might try this:
num var word
sw1 Pin 0
sw2 Pin 1
num = 100
start:
if sw1 = 0 then num = num + 1
if sw2 = 0 then num = num - 1
debug dec ? num, cr
pause 1000
goto start
Sid Weaver
512K plug-in EEPROM.......
http://www.visualmuses.com/chipcircuit/index.html
> a time interval.
num var word
sw1 Pin 0
sw2 Pin 1
num = 100
start:
debug dec ? num, cr
pause 1000
goto start
Sid Weaver
a time interval.
grivacoba@y...
some kind of display. What kind of display are you using?
-- Jon Williams
-- Dallas Office
From: grivacoba [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6_8WpCPwljJd4dAx7PIGnT9XDf-D4iKDyNwKFLHraO8FkEEdo01J3SROIPsTWs3846BV7AbE9IsU-K_v]grivacoba@y...[/url
Sent: Saturday, May 15, 2004 2:29 PM
Subject: [noparse][[/noparse]basicstamps] input decimal numbers to bs2
a time interval.
grivacoba@y...
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
That's not difficult, nor is it trivial -- and cannot be drafted without
From: grivacoba [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hsUQ5t0Q7xQW7ica4o8VoszkIxMNYyPlheCZETK3Hg9US4MxTPeiGyTzOnfDttltKyf7BMaDIuwpM3o]grivacoba@y...[/url
a time interval.
grivacoba@y...
Jon thanks for your help. I'm using an inexpansive LCD display 16x2 AC162A.
And the intention is to have an input number into a variable to be compare with another variable to output a result ig: if number_in = number_var then output
grivacoba
Do you Yahoo!?
SBC Yahoo! - Internet access at a great low price.
