2 to 2p serial
Hello. I am having trouble getting the BS2p24 recieve serial commands from a BS2. I am attempting to do this at 9600 baud. I am not using flow control as it is not needed for this application. I previously used 2 BS2s, but would like the 2p to replace one for some other processing, and larger code space.
BS2 subroutine:
sendf:
Serout 1,16468, [noparse][[/noparse]"F"]
return
BS2p code:
SERIN 1, 16624, [noparse][[/noparse]my_var]
debug my_var
my_var is a byte-sized variable. Is this (16624) the right number to use for 9600 baud on the 2p? Is 16468 on the 2 not "true" 9600 baud, but a little faster, or slower? According the the basic stamp manual, these are the right numbers. Would it be more safe to communicate slower? The only wiring is P1 to P1, a common ground, and 5v from a regulator (7805). The same wiring works when I replace the 2p with a 2, and change the code accordingly. Thank you for any help.
John Baker
http://www.geocities.com/johnsrobotics/
Do you Yahoo!?
SBC Yahoo! - Internet access at a great low price.
BS2 subroutine:
sendf:
return
BS2p code:
debug my_var
John Baker
Do you Yahoo!?
Stamp modules is to take advantage of the compiler's conditional
compilation capabilities. This structure is built right into my
template program so I never have to look-up baud rates.
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
T38K4 CON 45
#ENDSELECT
Inverted CON $4000
Open CON $8000
Baud CON T9600
I have posted my template and other files that take advantage of
conditional compilation in the File section on Yahoo Groups.
-- Jon Williams
-- Dallas Office
From: John Baker [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CVoG4wSUUdtq1LXRroasITUUYe1Uos7nOESXaq0x-1pyljEWd-67XC9iG_EnvttCRiKCCk4-YLej7qLV7LFiAJAD]johnbaker_erie_pa@y...[/url
Sent: Saturday, May 15, 2004 12:39 PM
Subject: [noparse][[/noparse]basicstamps] 2 to 2p serial
and larger code space. BS2 subroutine:
sendf:
return
BS2p code:
debug my_var
John Baker
John Baker
Jon Williams <jwilliams@p...> wrote:
An easy way to solve baud compatibility issues between different BASIC
#SELECT $STAMP
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
T38K4 CON 45
#ENDSELECT
Inverted CON $4000
Open CON $8000
Baud CON T9600
-- Jon Williams
-- Dallas Office
From: John Baker [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fFnmX8PBm7JfljH1twyCAG_jgllJB79lt1TbhaXP8A_CGz73ZLQTXVdA3wJ-4xOojDnrf4bRSI4RzLSshDRV3Duz4ns]johnbaker_erie_pa@y...[/url
sendf:
return
BS2p code:
debug my_var
John Baker
from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
nice, neat, and easy to read.
Jon Williams
From: John Baker [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YNRRzyLjrVQZQac_e0E4x0gVIpnhxy13Ve1Lfaz1gZOtaGVgG6iL_59ZGTYXKBEmR3MPRohpCmhY6lRx4hgJYxhVPE4]johnbaker_erie_pa@y...[/url
Sent: Sunday, May 16, 2004 5:21 PM
Subject: RE: [noparse][[/noparse]basicstamps] 2 to 2p serial
That saves a lot of time. Thanks.
John Baker
compilation capabilities. This structure is built right into my template
#SELECT $STAMP
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
T38K4 CON 45
#ENDSELECT
Inverted CON $4000
Open CON $8000
Baud CON T9600
-- Jon Williams
-- Dallas Office
sendf:
return
BS2p code:
debug my_var
John Baker
