sound interpretation with bs2p40??
i posted a similar message before where most thought what i want to
do would require a lot more processing power. however i think it's
simpler than that, i think. i want to use the bs2p40 to distinguish
between two different sounds. one a boo, like boooo, and the other
is clapping. i would think a mic in line would work, and then set
frequency levels accordingly. obviously the boo would have a lower
frequency than a clap. so if someone clapped or booed, the stamp
would act as a switch and turn on or off an apparatus. any ideas.
part #'s possible software? thanks for any help. mark
Unfortunatly, it's a little harder than you describe to recognize
sounds. I'm not an expert so please bear in mind that I could be
totally wrong but here is what I think you would need:
1. Mic pre amp circuit before the Basic Stamp
2. Analog to Digital convertor (not sure if stamps have them or
not).
3. One you sample the sound, you have to determine where the sound
starts and stops then find the dominate frequencies using something
like an FFT (Fast Fourier Transform).
4.You would create a template of the sound to check and compare it
against templates you had previously stored.
It's not impossible but it's not simple either. I have some VCP200
voice recognition chips around here somewhere (looking through desk
drawers) that Radio Shack used to sell. They could determine 8 or
so words with a pretty good accuracy but I haven't seen anything
like these in years.
Again, I've never done this and everything I just described could be
wrong. Is there anyone else in here that know about speech or sound
recognition?
I have read of a simple speech recognition technique that looks at
the total energy of the sound to recognize but I haven't tried it to
see if it works. I'll see if I can write up a quick demo app if I
get a chance.
Ken
http://www.speechchips.com
--- In basicstamps@yahoogroups.com, "sponsitility"
to
distinguish
I would not go to FFT with a Stamp :-) but try some filterbanks.
You could try a low pas filter RC whitch let's all frequency's below say 500
Hz go through for the BOOOOO's. And then a high pass filter above say 2000
Hz for the claps.
And then you will have to detect these frequencies with the samp. An ADC
might not be necessary as you could use the low/high level transition of an
input on the Stamp. And some potmeters to adjeut the levels.
Depending on the level of your input signal you may need an amplifier also.
This will be far more easy to implement than the FFT route for which the
Stamp is not powerfull enough anyway!
I hope this helps.
Klaus
Sent: Sunday, May 16, 2004 1:59 AM
Subject: [noparse][[/noparse]basicstamps] Re: sound interpretation with bs2p40??
> Hi Mark,
> not).
> recognition?
> get a chance.
> Ken
> to
> distinguish
> Yahoo! Groups Links
to
distinguish
I think you'll be better off using a speaker-independant speech
recognition chip. Even that may not work the way you want, but it
seems that what you want to do requires more signal processing in
terms of audio than what you will be able to do directly with the
BS2.
Knight Designs
signal, but you should be able to build a couple of analog band-pass
filters, or even a high-pass and low-pass filter pair. Anything of
sufficient amplitude below a given frequency (say 500 Hz) would trip a
one-shot pulse generator (a 555), and anything above a given frequency (say
1000 Hz) would trip the other one-shot.
Mike Sokol
mike@f...
www.fitsandstarts.com
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
> to
> distinguish
Do you have any links that would show such a circuit?
Ken
www.speechchips.com
--- In basicstamps@yahoogroups.com, "Mike Sokol" <mike@f...> wrote:
> This is way too complicated for a stamp to process as a digitized
audio
pass
trip a
frequency (say
> Mike Sokol
> mike@f...
> -William of Occam-
want
> > to
it's
> > distinguish
other
set
lower
stamp
ideas.
For those of you that don't remember the 60's, we had a groovy lighting
controller that would blink different color lights for bass, midrange, and
treble frequencies. FAR... OUT...!!!!
I think what you can do is hack the filters from a color organ circuit to
trigger separate outputs on a "clap" or a "boo". See
http://www3.telus.net/chemelec/Projects/Color-Organ/Color-Organ-2.jpg
You need to eliminate the direct A.C. power supply and run the LM324
OpAmp off the Stamp's 5 volt supply on pin 4 so the LM324 outputs swing
between .6 volts and 4.4 volts and send that to a 555 in one-shot mode. At
least as I remember an LM324 will get within .6 volts of the power supply
rails. Any other stampers please correct me if I'm wrong. Yes, I grew up and
learned electronics in the 60's...
Here's one example of 555 timer circuits:
http://ourworld.compuserve.com/homepages/Bill_Bowden/page9.htm
I'm sure there's about a million other versions on the web, but that's the
idea. Then use the 555 one-shot to drive the I/O pins on the Stamp.
You probably only need the filter circuits for the high-pass and low-pass
sections, then use one section of the LM324 to amplify the output of a Radio
Shack electret mic element which should cost a buck or two at most.
Mike Sokol
mike@f...
-William of Occam-
Sent: Wednesday, May 19, 2004 9:28 PM
> Mike,
> Thanks,
> Ken
> www.speechchips.com
> audio
> pass
> trip a
> frequency (say
> > Mike Sokol
> > mike@f...
> > -William of Occam-
> want
> > > to
> it's
> > > distinguish
> other
> set
> lower
> stamp
> ideas.
> Yahoo! Groups Links
