BS2p40 and ADNS optical mouse sensor
I am trying to interface my BS2p40 directly with an ADNS-2051 optical
mouse sensor to measure linear displacement. I have removed the
existing microcontroller from the mouse and I have referred to the
ADNS data sheet. After experimenting with the shiftin and shiftout
commands, the synchronous serial communications seem to be over my
head. Has anyone used this optical sensor before? I would greatly
appreciate any help.
Thanks, Bill
Thanks, Bill
Have you hacked the optical part of the mouse, also? How close do you have to get to the object to get good data?
Dave
Thanks, Bill
from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
SBC Yahoo! - Internet access at a great low price.
With little success using the serial communication, I am now
considering the quadrature outputs from the ADNS as well. One
problem I am running into is how to measure the relative timing of
the two (Xa, Xb - I only need one direction) signals by the stamp.
Pulsin measures it only on one pin and it seems that the relative
timing of high/low changes between the channels is the important
factor for determining the amount of motion. Is this right? Have
you gotten this to work yet?
As for the optical part, fortunately I am keeping the rest of the
mouse as is and mounting it just about touching the moving surface.
I am not sure of how close you have to be for good data. If you need
to go further, there is an article in the May 2004 Nuts & Volts (p86)
that describes modifying lenses for this sensor - it may be helpful.
Bill
--- In basicstamps@yahoogroups.com, David Anderson
<dersonquilter2@y...> wrote:
> It just so happens, I too am interfacing this same part to a Stamp!
I am using a BS2, and plan on using the quadrature outputs
(Xa,Xb,Ya,Yb) and PULSIN. If it works, this will be easier than the
serial data route.
> Dave
optical
> Thanks, Bill
> Yahoo! Groups Links
> Do you Yahoo!?
Referring to "Basic Stamp Commands, Features, and Projects", page 279, section 6.4, you will see a project that uses PULSIN on two pins simultaneously. This can be found under "Downloads/Documentation". For my application, I am only interested in relative speed of the movement, I don't care what the direction is. Therefore, I intend to use only the pin that has the shortest pulse width, "and throw the other one away". Thanks for the tip about the N&V article.
Dave
Hi Dave
Bill
serial data route.
> Dave
optical
> Thanks, Bill
> Yahoo! Groups Links
> Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
