ShiftIn, ShiftOut Replacement code
For Tracy Allen:
I tried your code, but unfortunately it won't compile:
The code below works fine with a short cable between the SHT1X and the BS2:
'sends "ioByte"
'returns "ackBit"
SHT_Write_Byte:
SHIFTOUT ShtData, Clock, MSBFIRST, [noparse][[/noparse]ioByte] ' send byte
SHIFTIN ShtData, Clock, LSBPRE, [noparse][[/noparse]ackBit\1] ' get ack bit
RETURN
'returns "ioByte"
'sends "ackBit"
SHT_Read_Byte:
SHIFTIN ShtData, Clock, MSBPRE, [noparse][[/noparse]ioByte] ' get byte
SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]ackBit\1] ' send ack bit
INPUT ShtData ' release data line
RETURN
where "ShtData" is set as a constant, or "ShtData CON 1"; "Clock" is set as a constant, or "Clock CON 0"; "ioByte" is set as a variable byte, or "ioByte VAR Byte"; "ackBit" is set as a variable bit, or "ackBit VAR Bit"
The below code which I put in to replace SHIFTOUT and SHIFTIN (The original SHIFTOUT, SHIFTIN code lines have been commented out) was supposed to work with a remoted SHT1X on a 50 foot piece of telephone line (4 wire), but always gives an error when I attempt to compile it. The error is on the line
"ShtData2=ioByte.BIT0(ToDelay)"
where the ShtData2 term is highlighted and the error note says "expected a Label, Variable, or Instruction". I tried to follow your previous advice on this, but........?? Would you, could you, please help me?
'sends "ioByte"
'returns "ackBit"
SHT_Write_Byte2:
'SHIFTOUT ShtData2, Clock2, MSBFIRST, [noparse][[/noparse]ioByte] ' send byte
FOR ToDelay = 7 TO 0 '7 to 0 is MSBFIRST
PULSEOUT Clock2,10 '10 milisecond clock pulse
NEXT
'SHIFTIN ShtData2, Clock2, LSBPRE, [noparse][[/noparse]ackBit\1] ' get ack bit
FOR ToDelay = 0 TO 1 '0 to 1 is LSBPRE, 1 Bit Only
ackBit.BIT0(ToDelay)=ShtData2 'ackBit valid pre clock pulse
RETURN
'returns "ioByte"
'sends "ackBit"
SHT_Read_Byte2:
'SHIFTIN ShtData2, Clock2, MSBPRE, [noparse][[/noparse]ioByte] ' get byte
FOR ToDelay = 7 TO 0 '7 to 0 is MSBPRE
ioByte.BIT0(ToDelay)=ShtData2 'ShtData2 valid pre clock pulse
NEXT
'SHIFTOUT ShtData2, Clock2, LSBFIRST, [noparse][[/noparse]ackBit\1] ' send ack bit
FOR ToDelay = 0 TO 1 '0 to 1 is LSBFIRST, 1 Bit Only
ackBit.BIT0(ToDelay)=ShtData2 'ackBit valid clock pulse
NEXT
INPUT ShtData2 ' release data line
RETURN
Many thanks for your previous advice and any help you can offer further.
Kindest regards, Chuck Irwin
'sends "ioByte"
'returns "ackBit"
SHT_Write_Byte:
RETURN
'returns "ioByte"
'sends "ackBit"
SHT_Read_Byte:
RETURN
'sends "ioByte"
'returns "ackBit"
SHT_Write_Byte2:
NEXT
RETURN
'returns "ioByte"
'sends "ackBit"
SHT_Read_Byte2:
NEXT
NEXT
RETURN
That sounds like you might not have defined ShtData2 correctly. The
best way to define it under PBASIC 2.5 is by using the new "PIN"
declaration, as follows. Also, I think you will need to use the
OUTPUT and INPUT commands to set the pin direction.
ShtData2 PIN 1
Clock2 PIN 0
ToDelay VAR Nib
ioByte VAR Byte
SHT_Write_Byte2:
OUTPUT ShtData2 ' the pin needs to be an output
ShtData2=ioByte.BIT0(ToDelay) ' sets the output register
NEXT
SHT_Read_Byte2:
INPUT ShtData2 ' the pin needs to be an inout
NEXT
I hope that helps?
-- Tracy
>For Tracy Allen:
>'sends "ioByte"
>'returns "ackBit"
>SHT_Write_Byte:
> RETURN
>'returns "ioByte"
>'sends "ackBit"
>SHT_Read_Byte:
> INPUT ShtData
>' release data line
> RETURN
>please help me?
>'sends "ioByte"
>'returns "ackBit"
>SHT_Write_Byte2:
>'7 to 0 is MSBFIRST
> NEXT
>LSBPRE, 1 Bit Only
>clock pulse
> RETURN
>'returns "ioByte"
>'sends "ackBit"
>SHT_Read_Byte2:
>clock pulse
> NEXT
> NEXT
> RETURN
