Count Fonction
Hi every body,
Is there a way to get real time count using the Count format, Because
I need to count pulse from rotary encoder then serial out to visual
basic prog. Some one can be give some tip about.
<christian_vermette@v...> wrote:
> Hi every body,
Because
Christian,
Attached is a bit of code to read an encoder. It will
track which direction the encoder is turning and will run
up to 50 Hz if you can keep the program short.
' {$stamp bs2}
' Program to act as high speed quadrature counter
' Program Name: quadhicount.bs2
' Last Update: Mar 10/01 tjs
DIRH=%11111111
counter VAR Word
counter2 VAR Word
counter3 VAR Word
old VAR Nib
new VAR Nib
direct VAR Byte
' Channel a and b of encoder go on inputs 6 and 7 in this case.
quad:
counter=127 'load a dummy value so can count up or down
new = INB & %0011 ' get initial condition
start:
old = new & %0011 ' remember initial setting
again:
new = INB & %0011 ' get new reading
IF new=old THEN again
direct=new.BIT1 ^ old.BIT0 ' XOR left bit of new with right bit
of old to get direction
IF direct=1 THEN cw ' jump here to increment
LOW 0 ' pin 0 turns led off if turning counter-
clockwise
counter=counter-1 ' jump here to decrement
OUTH=counter.LOWBYTE
GOTO start
cw:
HIGH 0 ' pin 0 turns on led if turning clockwise
counter=counter+1
OUTH=counter.LOWBYTE 'turn on leds on pins 8 through 15 to watch
count
GOTO start
Cheers,
Tom Sisk
for your quick response, but I am not able to run the program you given me,
I have signal going to pin 6 and 7 (Channel A and
already place an Schmitt trigger, led on pin 8 doesn't go on even the way I
turn the motor.
Can you give me more in
Christian
From: stamptrol [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=88IpXPd8U31CwLKzQxEE8usTTJDiJDaRdEbV3WMNSiROjMIkIN4BXcWmZw8HsMjK5naJEsSx7wVfCfLC1EtpdQ]sisk1404@n...[/url
Sent: 11 mai, 2004 19:16
Subject: [noparse][[/noparse]basicstamps] Re: Count Fonction
--- In basicstamps@yahoogroups.com, "vermettechristian"
> Hi every body,
Because
Christian,
' {$stamp bs2}
DIRH=%11111111
counter VAR Word
counter2 VAR Word
counter3 VAR Word
old VAR Nib
new VAR Nib
direct VAR Byte
quad:
start:
again:
clockwise
GOTO start
cw:
counter=counter+1
count
GOTO start
Cheers,
Tom Sisk
Yahoo! Groups Links
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.679 / Virus Database: 441 - Release Date: 04-05-07
I am looking for a way to read pulse from rotary encoder, at this time I use
the program below, but I have problem it only decrease the value even if the
motor turning CW or CCW. Some one have some tips for me.
' {$stamp bs2}
'{$PORT COM1}
DIRH = %11111111
counter VAR Word
counter2 VAR Word
counter3 VAR Word
old VAR nib
new VAR Nib
directn VAR Byte
quad:
counter = 125 'load a dummy value so can count up or down
start:
Again:
IF new = old THEN again
directn = new.BIT1 ^ old.BIT0 ' XOR left bit of new with right bit of
IF directn = 1 THEN CW ' jump here to increment
counter-clockwise
counter = (counter+1) ' jump here to decrement
OUTH = counter
DEBUG DEC counter,cr
GOTO again
CW:
counter = (counter-1)
OUTH = counter 'turn on leds on pins 8 through 15 to watch
DEBUG DEC counter,CR
GOTO start
Thank you
Christian
From: Christian Vermette [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=O9namEkaxjT0YFVDQJMsdLTwYcjs5GEXMXVhoYquiK48LUt7JVoVask9yeYnbY6E1hjQvszne2D0fC_ORy7k_LH4KVDTEQ]christian_vermette@v...[/url
Sent: 11 mai, 2004 20:17
Subject: RE: [noparse][[/noparse]basicstamps] Re: Count Fonction
Thank you Tom
turn the motor.
Christian
From: stamptrol [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kRS180G_NI5J4RiIqxrbagFC4fi-PB-S6LnMavykzACM9Y-pINrvl_yUSTiCvGShZo52b6HRW2SzVVO-l-v6ZlAqOA]sisk1404@n...[/url
> Hi every body,
Because
Christian,
' {$stamp bs2}
DIRH=%11111111
counter VAR Word
counter2 VAR Word
counter3 VAR Word
old VAR Nib
new VAR Nib
direct VAR Byte
quad:
start:
again:
clockwise
GOTO start
cw:
counter=counter+1
count
GOTO start
Cheers,
Tom Sisk
Yahoo! Groups Links
Yahoo! Groups Links
