Basic Stamp Assistance - Water Timer
--- In basicstamps@yahoogroups.com, "Tom" <mtsue@q...> wrote:
> What I am trying to do is develop a battery operated water timer
such as
> Nelson or Toro. I would like the timer (it doesn't matter what
functions it
> has) to be able to push a "START" button for instance (all I need
is one
> button).
> Push the "START" button, the water valve opens.
> Water valve stays open for 10 minutes, then closes.
> NOW - The valve remains closed for another 10 minutes.
> During the 10 minutes, the valve may not be opened (say by
pressing the
> START button again) until the 10 minutes are up.
> Then the valve may be opened again by pressing START again, and
repeating
> the cycle if desired.
> Thank you, Tom
Hi Tom,
It sounds toooooo simiple.
One input
two internal timers
one output.
BS1 will handle this with no problem unless you want to make it
really fancy.
A person of your capabilities ....
-can ask a question
-can word it logically
-can access the internet
-can follow instruciotns (going from SRG to this list)
-and can inteurpet things that are new.
you should be able to write a Stamp program in short order and have
fun while learning how to program.
if you want some ideas, conisdder a 4 second push and hold. hold the
button for over 4 seconds and it would enter another mode, like an
override.
add a beeper so you know what is happening.
that way, you could override the unit and get a longer run time....
possibly have it turn on in half cycles if the button is pressed
repeatedly... kinda like if you hit it 3 ties in 30 seconds, you can
get a 5 minute run starting now, regardless of when it was last off.
possibly a 5 push off so that 5 pushes in 5 seconds allows you to
stop shut off the valve.
Dave
such as
functions it
is one
> button).
pressing the
repeating
> Thank you, Tom
Hi Tom,
One input
two internal timers
one output.
really fancy.
-can ask a question
override.
Dave
