bs2 p40 and cmucam
Hello,
I have another problem again:
I changed the Stamp from BS2 to BS2p40 and used following program to
test communication between the stam and the CmuCam:
'{$STAMP BS2p}
'{$PBASIC 2.5}
PAUSE 1000
SEROUT 10, 240, [noparse][[/noparse]"RS", CR]
SERIN 9, 240, [noparse][[/noparse]WAIT (":")]
Main:
SEROUT 10, 240, [noparse][[/noparse]"L1 1",CR]
DEBUG "LED on ACK: received OK",CR
PAUSE 500
SEROUT 10, 240, [noparse][[/noparse]"L1 2",CR]
DEBUG "LED off ACK: received OK",CR
PAUSE 500
GOTO Main
Changing 84 (baudmode value for BS2) to 240 didnt give the solution.
In addition to that, I put a DEBUG " " between each SERIN and SEROUT
and program worked ok.
Can someone explain me what happens when I put DEBUG? Is it only
about delay time that the command DEBUG causes or is there anything
else more subtle?
Thank you very much
Murat
'{$STAMP BS2p}
'{$PBASIC 2.5}
PAUSE 1000
Main:
PAUSE 500
PAUSE 500
GOTO Main
else more subtle?
Thank you very much
Murat
keep them from working with the stamp IDE
unless you have at least one debug statement.
--- In basicstamps@yahoogroups.com, "m_a_y_y_i_l_d_i_z"
<mayyildiz@m...> wrote:
> Hello,
to
> '{$STAMP BS2p}
> '{$PBASIC 2.5}
> PAUSE 1000
> Main:
> PAUSE 500
> PAUSE 500
> GOTO Main
solution.
SEROUT
> else more subtle?
> Thank you very much
> Murat
