Parallel LCD program — Parallax Forums
edited 2004-05-06 22:23 in General Discussion
I have an LCD from a HP printer. It has a Hitachi (?) chip HD44780S on the
back and 14 pins on the left edge. I would like to write a program for my
Stamp to convert this to a serial LCD. Does anyone have such a program?
It looks like it is a 2 x 20.
Sid Weaver
    edited 2004-05-06 15:17
    In a message dated 5/6/2004 2:10:10 PM Eastern Daylight Time,
    klausdejong@x... writes:
    > Below you find (part of) the code I use for my Hitachi 2X8 and 2x16
    > displays. It is designed for 4 bit data transfer and 3 bit control
    > for the display. I normaly use pins 9, 10, 11 for the control and
    > 12,13,14,15 for the data.
    Thanks, Klaus. I'll see if I can puzzle out the code. One question, where
    do I connect the 14 pins on the LCD. They must go to the Stamp somewhere.
    Sid
    edited 2004-05-06 19:06
    Hi Sid,
    I hope this helps,
    Klaus
    A substantial part of the code below is "borrowed" from Jon
    Williams :-)
    >>>>>>>>>>>>>>>>>>>>>>>Example of sendtext
    'DISPLAY
    ' FOR idx = 2 TO 1
    ' char = Ts DIG idx + 48
    ' GOSUB SENDTEXT
    ' NEXT
    ' char = "."
    ' GOSUB SENDTEXT
    ' char = ts DIG 0 + 48
    '' GOSUB NEXT_LINE
    >>>>>>>>>>>>>>>>>>> initializing Display
    RS CON 9
    RW CON 10
    E CON 11
    CHAR VAR Byte
    INST VAR CHAR
    'INDEX VAR Word
    TEMP VAR Byte
    idx VAR Byte
    LOW RW
    OUTH = %00000000
    DIRH = %11111111
    GOSUB INITLCD
    'Einde Display initialisatie
    >>>>>>>>>>>>>>>>>>>>>>>>>Display numbers and characters
    Some Subroutine:
    GOSUB CLEARSCREEN
    FOR idx = 2 TO 1
    char = Temperatuur DIG idx + 48
    GOSUB SENDTEXT
    NEXT
    char = "."
    GOSUB SENDTEXT
    char = Temperatuur DIG 0 + 48
    GOSUB SENDTEXT
    char = 223
    GOSUB SENDTEXT
    char = "C"
    GOSUB SENDTEXT
    FOR idx = 1 TO 0
    char = Wind DIG idx + 48
    GOSUB SENDTEXT
    NEXT
    char = "B"
    GOSUB SENDTEXT
    char = "f"
    GOSUB SENDTEXT
    GOSUB NEXT_LINE
    Return
    >>>>>>>>>>>>>>>>>>>>>>>> Routine for Hitachi
    INITLCD:
    PAUSE 200
    LOW RS
    LOW RW
    OUTH = %00110000
    PULSOUT E,1 'INITIALISATIE DISPLAY
    PAUSE 10
    PULSOUT E,1
    PAUSE 1
    PULSOUT E,1
    PAUSE 1
    OUTH = %00100000
    PULSOUT E,1 'KIES 4-BIT TRANSFER
    INST = %00101000
    GOSUB SENDINST 'DISPLAY AAN, KIES 2 REGEL DISPLAY
    INST = %00001110
    GOSUB SENDINST 'CURSOR AAN
    INST = %00000001
    GOSUB SENDINST 'DISPLAY WISSEN
    INST = %00000110
    GOSUB SENDINST 'ENTRYMODE AUTOINCREMENT
    INST = 14
    GOSUB SENDINST 'CURSOR UNDERLINE
    RETURN
    CLEARSCREEN:
    INST = %00000001
    RETURN
    SENDINST:
    PAUSE 1
    LOW RS
    OUTD=INST.HIGHNIB
    PULSOUT E,1
    OUTD=INST.LOWNIB
    PULSOUT E,1
    HIGH RS
    RETURN
    SENDTEXT:
    HIGH RS
    OUTD=CHAR.HIGHNIB
    PULSOUT E,1
    OUTD=CHAR.LOWNIB
    PULSOUT E,1
    RETURN
    NEXT_LINE:
    INST = 128+64
    GOSUB SENDINST
    RETURN
    Sent: Thursday, May 06, 2004 4:22 PM
    Subject: [noparse][[/noparse]basicstamps] Parallel LCD program
    HD44780S on
    the
    for my
    program?
    > Thanks
    > Sid Weaver
    > from the same email address that you subscribed. Text in the
    Subject and
    > Yahoo! Groups Links
    Hi Sid,
    In fact you can use only a nibble for the data and shift them into
    the LCD in two passes, that is pins 11,12,13,14 on the LCD. Pins
    4,5,6 on the LCD are for control tasks. Then pin 1 == GND, 2 == VDD
    and 3 == contrast. So pins 7,8,9,10 on the LCD are not used saving
    you 4 pins on the Stamp. This way you use only 7 instead of 11
    expensive I/O on your Stamp.
    Tip: search the web for HD44780 or KS0066
    Klaus
    PS it's a nice puzzle to get this working :-).
    2x16
    control
    question, where
    somewhere.
    > Sid
