Averaging numbers over a long time
Archiver
In a message dated 5/4/2004 12:52:18 PM Eastern Daylight Time,
laurasdog@w... writes:
> I am trying to gather power data from a small wind generator.
> Voltage and current are sampled aprox twice per second
> with a 12-bit ADC and data is fed to a BS2.
> Numbers are crunched and instantaneous and peak
> voltage, current, and power are displayed on an LCD display.
> There is no real time clock, so the number of samples
> in a day is only approximately known
One of the problems here is that if you continually sum the satts, it won't
be long before you reach 65535 and roll over, thus losing your total. I have a
scheme I am using in a data logger that might help if you care to contact me
off line. I'm not guaranteeing a solution, only a bit of help.
Sid Weaver
256K of plugin EEPROM................
http://www.visualmuses.com/chipcircuit/index.html
Sid Weaver
The problem I'm having is with the "average watts" portion of it.
I need to average the watts over time (possibly as long
as a month) and keep a running *average* (not total) on the
watts produced. The peak watts at any time could go as
high as 700. (but anything over 500 is pretty scary!)
Output could also be zero for hours or days at a time.
I seem to be having trouble finding a solution to this without
using up a ton of memory space. Wish I'd paid more
attention in math class all those years ago...
Could anyone help get me started in the right direction?
Thanks much,
Steve
===The computer this message====
===was sent from runs exclusively==
===on renewable energy sources===
>have a
>Sid Weaver
Thanks Sid,
I was hoping there might be some sort of slick way to "average as you go".
Perhaps save samples until you get close to the 65K limit, then average.
Save that number and grab the next load of samples and average those..
or something like that. The *average* is unlikely to exceed a few hundred
watts. I suppose I could add more memory, but due to bad planning I'm
just about out of I/O and 3 more lines would be tough to come up with...
Steve
> Greetings group,
> Thanks much,
> Steve
It is simple to do a running average with a few variables.
RD = Raw data is, well, raw data.
AVG = average is well, average.
HLD = holder is a holder for the math
if you take
HLD = HLD + RD ; simple enough, you are just adding a new value.
AVG = HLD / 10 ; this makes the average,
;make sure HLD never exceeds your maximum value
HLD = HLD-AVG ; here is the way to keep the
; total counts in the holder low
It will take about 100 readings for a change to be fully implemented.
This would not be trying to call a do loop or anything fancy, it
would just take each new reading, add it to the total, then divide by
a number. I used 10 for an example.
The main thing is that you can't have a WORD as the variable and
average 10 values of 60,000.
the problem with this is that it acts like a noise filter. If you
ran near 100% for 30 days, then near zero, it would report zero in
short order.
A variance is to take your raw data and divide that by 10. since it
is only an average, the last number is not important anyway.
Another method might be to look at the differences in the readings
and average those.
But, if you are looking for a usage meter then a whole different
approach would be needed.
Assuming you take one reading a minute.
you could check to see if that reading is less than 10%, between 10
and 20, between 20-30 or 30-40 and so on.
Then just keep a value of how many times the reading is less than
10%, between 10 and 20 and so on.
You only increment your value by one regardless of the real value.
Then if you also keep track of how many readings, you can figure the
average.
you could use a look-up table with 100 points to get an accuracy of
1%.
One problem is how often you need to take a reading. once per second
will yield 86,400 seconds per day. if you increment by 1 for each
reading you will soon run out of space.
Once a minute is 44,640 in 31 days.
If you really wanted one reading per second and had 100 levels to
read, you could multiply that by having another counter of each time
any reading hit say, 60,000. a second variable would see the reading
reaching 60,000 then adding one to it's value and resetting the
60,000 back to zero.
Another option is data logging.
A 512k EEPROM would hold a lot of data, but packing it in there is a
challenge. If you tried to time stamp, the time would take up half
of the space.
Dave
CC-EEPROM is waiting photos, but currently in the pending product
link.
>>have a
>>Sid Weaver
>Thanks Sid,
>Steve
Steve -
You may find it of interest to glance through some of Tracy Allen's notes here
on developing statistics and the Stamp:
http://www.emesystems.com/BS2math5.htm
You may also want to scan the archives here, and look for both "averaging", and "boxcar averaging". Both topics have been discussed at length in the past.
Bruce Bates
<snip>
<snip>
>short order.
Dave, I'm actually using this type of scheme already as a noise
filter for the voltage processing part. Works great! But, alas... it
doesn't work well for long term averaging for the reason you
mentioned.
>average.
>1%.
Hmmm. This may be promising. An accuracy of 5% would be
acceptable for this project. I'll have to think about this one for a bit.
Maybe I'll have to rip up some of my circuitry and redesign to
recover some of my I/O so I can use an external EEPROM. Sigh...
Thanks very much,
Steve
> >One of the problems here is that if you continually sum the watts,
it won't
total. I
> >have a
contact me
> >Sid Weaver
> Thanks Sid,
you go".
average.
those..
hundred
I'm
with...
> Steve
Interesting, if you have any serial already, all you need is one
line for the SPI to select the chip. If I2C, you may be able to get
by with a hardware address on the memory.
But, if you added a chip riser, with a port expander or even a 595
and then re-direct some output pins....
Some of this is just not simple !
Dave
Try a variety of exponential smoothing. It is fairly clearly explained
in MS Excel's help. Hardly any memory used.
Dov Yassky
5, Shapira Street
Tel Aviv 64358
Israel
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zyrLGhaYj4rI6vGJjyMEqLnwf3V6ao_nf_HOZlbQofs0D6ndfq37VVktzxMpu2fxOijj9QczcbZM2vqUBl0cBfkVHbkNTg]laurasdog@w...[/url
Sent: Tuesday, May 04, 2004 6:50 PM
Subject: [noparse][[/noparse]basicstamps] Averaging numbers over a long time
Greetings group,
I am trying to gather power data from a small wind generator. Voltage
and current are sampled aprox twice per second with a 12-bit ADC and
data is fed to a BS2. Numbers are crunched and instantaneous and peak
voltage, current, and power are displayed on an LCD display. There is no
real time clock, so the number of samples in a day is only approximately
known
The problem I'm having is with the "average watts" portion of it. I need
to average the watts over time (possibly as long as a month) and keep a
running *average* (not total) on the watts produced. The peak watts at
any time could go as high as 700. (but anything over 500 is pretty
scary!) Output could also be zero for hours or days at a time.
I seem to be having trouble finding a solution to this without using up
a ton of memory space. Wish I'd paid more attention in math class all
those years ago...
Thanks much,
Steve
Yahoo! Groups Links
