Software to use PC as oscilloscope
In a message dated 5/4/2004 10:49:11 AM Eastern Daylight Time,
jhavins@e... writes:
> I am new to the Group and have searched the archives (briefly) for
> suggestions on software that might allow a PC to be used as an
> oscilloscope to aid with BASIC Stamp project development. Any
> recommendations?
Yes - take a look at the Optascope at Parallax. Great little tool !
Sid Weaver
256K of plugin EEPROM................
http://www.visualmuses.com/chipcircuit/index.html
> recommendations?
Sid Weaver
Hello to all!
recommendations?
Or should I look at eBay to see what is available in a "stand
alone" 'scope?
Also, with either alternative, what speed (e.g., 100 Mhz, etc.) is
adequate for viewing BASIC Stamp and related signals? And what
probes would prove most useful?
Thank you in advance for your courtesy. I am confident that the
wisdom and experience of the Group will help me keep from blowing
money on what might turn into a "doorstop!"
Cheers!
Bill
You might want to check out www.jameco.com as well, they have a couple of
different packages that will allow you to turn your PC into an O'scope
Randy Abernathy
4626 Old Stilesboro Road NW
Acworth, GA 30101-4066
Phone / Fax: 770-974-5295
Mobile: 678-772-4113
E-mail: cnc002@a...
I furnish technical support, repair, and other related services for your
industrial woodworking machinery. My background as Senior Service Engineer for the
SCMI Group for nearly fifteen years with factory training, combines with my
extensive background in electronics, mechanics, pneumatics, electrical and CNC
machinery to offer you needed support for your machinery.
recommendations?
alone" 'scope?
Cheers!
Bill
for
> > recommendations?
tool !
> Sid Weaver
> Check out the latest issue of Nuts and Volts...There is freeware
available...Winscope.zip...at www.nutsvolts.com
<http://www.geocities.com/nlradiofm/winscope.htm>
<http://polly.phys.msu.su/~zeld/oscill.html>
and here's one that does real time Frequency Analysis:
<http://www.relisoft.com/freeware/>
look for "frequency Analyzer" link or just use this:
<http://www.relisoft.com/freq.zip>
These need a Windows PC & sound card and they work pretty darn good! [noparse]:)[/noparse]
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
billinjoplin said:
> Hello to all!
> recommendations?
> alone" 'scope?
> Cheers!
> Bill
> Body of the message will be ignored.
> Yahoo! Groups Links
Choices abound in the 'scope department, and I can only tell you my take.
For digital electronics, the Optascope is a great value. It has some
distinct limitations though. It is not very accurate at reading frequency,
there can be some (I think) impedance matching issues with probes and so on.
I really like the Optascope though, and use mine all the time. You can't
find anything else like it for the price.
I also have an old Tektronics 465M. This is a great old scope, although it
only goes to 1 mHz. However, it is bullet-proof, has a built in calibrator,
and can handle much higher voltages than the Optascope. The older Tek
'scopes can be had for very little, I got mine for about $75. I would like
to get a 100mHz 'scope though.
So, for me, this combination works well, was very cheap to get into, and
does about %75 of what I would like. When you consider the prices of the
higher end 'scopes, it is a good compromise for the "financially challenged"
like myself.
HTH,
Jonathan
www.madlabs.info
Sent: Tuesday, May 04, 2004 5:42 AM
Subject: [noparse][[/noparse]basicstamps] Software to use PC as oscilloscope
> Hello to all!
> recommendations?
> alone" 'scope?
> Cheers!
> Bill
> Yahoo! Groups Links
You could probably do everything you need to do with just a logic probe. The
only times I've had to grab my scope was for serial (RS232 & I2C) & PWM and
typically they ether work or they don't. (FYI: I spent over an hour once
tweaking inop code before I realized that I was connected to the wrong pin!)
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
wrote:
> Hello to all!
> ...suggestions on software that might allow a PC to be used as an
> oscilloscope to aid with BASIC Stamp project development...
> Cheers!
> Bill
Thank you to everyone who responded. Good suggestions! Now I have
some homework to do to get this set up.
Cheers!
Bill
