Wallwart to BoE
Well this may or may not be a stupid question, I have
just taken delivery of my first stamp (BS2) after some
great advice from this list I opted to get the basic
Education Kit, and so today was the first opportunity
I have had to "play".
At the time of ordering I purchased the appropriate
wallwart from Parallax , so before actually plugging
the power unit into the BoE I checked it with my
multimeter and the reading I got was 16.7V. Is this
right I double checked with a different multimeter and
got the same reading. I thought it was supposed to be
9v? Well I am up and running with a 9v battery for
now. So whilst this message is being posted I can
continue working my way through the WAM manual.
Thanks Nigel
__________________________________
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
http://hotjobs.sweepstakes.yahoo.com/careermakeover
Thanks Nigel
Do you Yahoo!?
Many have asked the same question, and I discuss it (and a few other things)
in a little article at:
http://www.glitchbuster.com/wallwart.htm
-Randy
Sent: Sunday, May 02, 2004 1:21 PM
Subject: [noparse][[/noparse]basicstamps] Re: Wallwart to BoE
> Thanks Nigel
> Do you Yahoo!?
> Yahoo! Groups Links
answer. For now, though:
The open-circuit (nothing connected but a
high-impedance voltmeter) voltage on a wall-wart
can be much higher (up to 10 volts or so) than
the loaded (delivering 100 or 200 mA to a
circuit) voltage.
So, your wall-wart is NOT broken, and when you
actually connect it the voltage should drop some.
Note the rating (9V at 300 mA) means that when
it is delivery 300 mA, it SHOULD be AROUND 9volts.
Wall-warts tend to be very simple (transformer and
diodes and one capacitor). That's why you have an
on-board regulator, to take whatever stuff the
wall-wart hands out, and convert it to nice,
clean, steady 5Volts.
--- In basicstamps@yahoogroups.com, "Randy Jones" <randyjones@w...>
wrote:
> Hi Nigel,
other things)
> -Randy
> From: "Nigel Emms" <rulingshogun@y...>
> > Thanks Nigel
> > Do you Yahoo!?
Subject and
> > Yahoo! Groups Links
5.5 volts, or 9V (a 9V battery actually fluctuates fairly widely as to the
amount of voltage delivered...), or 16.7v, or 12v. The difference is
dissapated in heat, so if you're going to drive it at 6 VS 16 volts, you
may want to consider changing the size of your heat sink.
> Thanks Nigel
> Do you Yahoo!?
> from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
> Yahoo! Groups Links
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
> in a little article at: <http://www.glitchbuster.com/wallwart.htm>.
Enjoyed the read. Thx.
BTW: Zialog's eZ80 comes with several "switching" wall warts. NO
TRANSFORMER! ;-) I believe that this is a sign of things to come. They're
smaller, lighter, generate less heat and are regulated! Mass production will
probably make them cheaper than the heavy transformer versions so I can see
them really taking off.
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
Sean brings up a good point about the heat dissipated by the voltage
regulator. The BS2's regulator would be more of an issue than the
BOE's regulator, as the BS2 has no heat sink to replace.
Looking through Parallax's documentation, I found that they recommend
keeping Vin under 12V even though they specify 6-15V as valid. It
seems the consensus has been that your wall wart is most likely working
just fine, but I would test the voltage at the BS2's Vin pin with
everything powered up anyhow.
John Butera
On May 3, 2004, at 2:32 PM, Sean T. Lamont .lost. wrote:
> The 1605 voltage regulator needs to be overdriven. It can be
> overdriven at
> the
> you
