motordriver and RC control
hello,
I want to use an RC remote control to control a small motor. The receiver
makes an PWM pulse in my opinion, (i can attach a servo that turns left and
right) and i think i can put the PWM pulse in a H-bridge. I guess so far so
good....
How can I make that the motor go in reverse, if i change the control from
going forward to backward?
thanks pieter-jan
_________________________________________________________________
MSN Search, for accurate results! http://search.msn.nl
good....
thanks pieter-jan
<diepenpj@h...> wrote:
> hello,
receiver
left and
so far so
> good....
control from
> thanks pieter-jan
Read up more on the H-Bridge. in it's relaxed state, it will drive
one way. but when you energize the direction pins, it reverses the
polarity that goes to the motor and that makes the motor spin
backwards.
Dave
NEW ! Low profile Chipircuits
http://www.visualmuses.com/chipcircuit/index.html
> good....
Two possible solutions:
1) Borrow the guts from an old (mechanically broken) servo. Center the POT
and replace their motor with yours. Pull back RC remote control to reverse,
push forward to go forward; center to stop. done.
2) Run PWM thru power driver; reverse polarity of motor via a relay
(controlled by digital channel of RC)
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
