most likely not while operating. There might be a way just for the programming part though...
tyckihd <tycki@h...> wrote:Is it posible to power the BS2 from serial port while operating
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
No.
The serial port is a signal port and will only deliver about 10mA
maximum.
The spec for the parallel port is that if it delivers over 2.5mA at
over 2.5 volts, it is within spec. Laptops use a much lower power
output, typically just over 3 volts on the parallel port signals.
The Serial has more powre availble, but fewer pins. The +/- 14V
looks attractive, but the port will quickly drop voltage as you add
load.
The keyboard and mouse ports offer a lot of power if you are looking
for a power source.
The joystick port is the big winner here. Becareful, you can draw
amps and burn traces on the MB, then no joy.
The USB offers about 500mA max.
Also, you can add a power port to the PC and connect your 5 and 12 to
that for most projects. the average power supply is way
underutilized.
No.
maximum.
load.
for a power source.
underutilized.
Maybe Al Willimas can post his link to that ?
Dave
Dave
I just talked to CH products about how much power I could get from the
GameCard 3 Automatic (old product I have in a machine). They said it'll
deliver whatever the ISA (its an ISA slot card) spec can deliver, without
damage to the card. Of course, this just means that the card won't melt if
you draw more than the motherboard can handle - the motherboard may turn
into a smoking heap of ash.
--- In basicstamps@yahoogroups.com, PatM <pmeloy@s...> wrote:
> > From: Dave Mucha [noparse][[/noparse]mailto:davemucha@j...]
> > Sent: May 2, 2004 8:50 AM
> > To: basicstamps@yahoogroups.com
> > Subject: [noparse][[/noparse]basicstamps] Re: Power to stamp
> <Snip>
> </snip>
the
it'll
without
melt if
turn
Yup !
If you try to source 20ma per output on a Stamp you may release some
of the magic smoke !
Yahoo! Groups Links
Do you Yahoo!?
No.
maximum.
load.
for a power source.
underutilized.
Dave
Dave
Do be careful not to short it out or you will reboot your computer or worse.
Inline fuse holders are probably smart.
Al Williams
AWC
* Kits!
http://www.awce.com/kits.htm
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZIPLGwex2FAMxq9Iie9AElsnAfWGiGU53CBlgehqdWfEdpXgztRyQomqsob4aJe3YkbMy-1GUn8fhH0]davemucha@j...[/url
Sent: Sunday, May 02, 2004 10:50 AM
No.
maximum.
load.
for a power source.
underutilized.
Dave
Dave
Yahoo! Groups Links
> From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gF4AjtHSO1K2blFEV8_P-KBKA2FV1CcYgv9wyjA4FU0h2zfH0eFTCOpD-I_EW1g4a96Wk9qudSBM52Q9]davemucha@j...[/url
<Snip>
</snip>
> <Snip>
> </snip>
the
it'll
without
melt if
turn
Yup !
Dave
NEW ! Low profile Chipircuits
http://www.visualmuses.com/chipcircuit/index.html
thanks this helps
