slot cars
Hello all and thanks for the help. Here is my problem!
I need a program that will (on a figure eight slot car set)(using
momentary switches) create a zone around the crash area so that if
one car is running continuously and the other is manually
controlled, stop the continuously running car when the manually run
car is near the crash area. Any ideas. Thanks Rick
geowar@a... writes:
> I'd go optical; place an IR emitter/detector pair across the track before
> the controlled car enters the intersection and have it disable the power for
> the other car (but only for the section before it enters the intersection
> from the other direction).
Good idea - you can find the IR stuff you need at www.rentron.com.
Sid Weaver
I2C on a BS2 platform.................
http://www.visualmuses.com/chipcircuit/index.html
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
you have a thought on the direction to take in writing the code.
Thanks Rick
--- In basicstamps@yahoogroups.com, Newzed@a... wrote:
> In a message dated 5/1/2004 7:23:16 PM Eastern Daylight Time,
> geowar@a... writes:
track before
the power for
intersection
> Sid Weaver
rcrelauctions <rcrelauctions@y...> wrote:
Great idea, we had thought of using momentary switches also. Do
Thanks Rick
> geowar@a... writes:
track before
the power for
intersection
> Sid Weaver
from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
Yahoo! Groups Links
t
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
trains, to determine when a train was at a certain track
location.
A modified section of track might do it....
...Make two very small cuts or breaks in the track.
rejoin the cuts with 5 Ohm resistors.
i.e.
o---X---o
o---X---o
o--/\/\-o o--/\/\-o
o
o
| reverse biased diodes |
o
o
X = cut in track
Diodes should be rated at least 2X motor current draw
...Now monitor the voltage across each resistor( If
you don't care about direction, just use one resistor)
A voltage spike upward would indicate that a car has entered
the modified track section.
A voltage spike downward would indicate that a car has left
Speed could be calculated based on the length of track and
duration of time spent on the modified track.
>Thanks Rick
> > geowar@a... writes:
>track before
>the power for
>intersection
> > Sid Weaver
>Yahoo! Groups Links
Beau Schwabe Mask Designer National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Home: polygon_man@h... Mail Stop GA1
Work: bschwabe@a... Norcross, GA 30071
