ADC_MAX186 to BSII
I am interfacing the BSII to the MAX186 ADC. Everything looks good,
but in the datasheet of MAX186, it specifies that this ADC shift
bits out and in simultaneously.
My code is like that:
shiftout Dout, CLK, MSBFIRST [noparse][[/noparse]Control\8]
shiftin Din, CLK, MSBPOST [noparse][[/noparse]RB1\8]
The thing is I'm shifting out bits but not simultaneously shifting
in to the BSII.
What can I do to solve that ?
in to the BSII.
Don't use the shiftin function, simply make sure that you still have the
chip selected, and read the pin that the Din is connected to. The
shiftout will output the 'clock information and data', and will
simultaneously cause the output to be 'presented' to the Din line. You
then simply look at the line.
BTW, is ********** your first name or your last name? Are you the
programmer formerly known as ##########?
David Erbas-White
>in to the BSII.
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
The way you are doing it is fine, except you will need to shift in 12
bits to get the full resolution. The '186 does have a turbo mode
that allows a uP to send out the new control byte while it is till
shifting in the previous result, but you can't do that on the Stamp.
You will simply shift out the control byte, and then shift in the
result.
-- Be sure to use the internally clocked conversion mode in the
control byte, because the Stamp is too slow to do an accurate
conversion with the external clock mode.
' from figure 9 in MAX186 data sheet
' internal clock mode timing
LOW chipselect
HIGH chipselect ' conversion in progress, 10 microseconds max
LOW Dout ' to be sure no spurious control byte
LOW chipselect
shiftin Din, CLK, MSBPOST [noparse][[/noparse]RB1\12]
HIGH chipselect ' finished
-- Tracy
>in to the BSII.
I still have some problems,
I declared Din as :
Din CON 2
So how would I just read this line and then display it.
David Erbas-White
>in to the BSII.
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
