No basic stamps found...
I've just bought a BS2sx and a basic stamp 2 carrier board. I didn't
own a serial cable so I made a straight-through cable on my own. Pins
2,3,4,5 (also 6 to 7) are connected and pin 2 and pin 3 are swapped,
following the picture at http://photos.groups.yahoo.
com/group/basicstamps/vwp?.dir=/serial+cable+diagrams&.src=gr&.
dnm=BS_2_RS-232_wiring_diagram.jpg&.view=t&.done=http%3a//photos.
groups.yahoo.com/group/basicstamps/lst%3f%26.dir=/serial%2bcable%
2bdiagrams%26.src=gr%26.view=t
I repeatedly get an error message (using: Stampw_v2.1_Beta_1.exe) "No
basic stamps found". When trying to identify basic stamp, I get
Loopback: yes and Echo: yes but device type is empty. FIFO is disabled
from COM1 and all programs using the port are shut down. I assume baud
rate (using: 9600) and all other setting are irrelevent. Power source
is a 9V battery connected to VIN and VSS.
BS2sx + carrier board picture: http://mikasuon.host.sk/BS2sx/BS2sx.jpg
Any suggestions?
Any suggestions?
Basic Stamp wants a straight through cable to an ordinary PC.
By the way, it sounds like I need to add some more cable info to
http://www.wd5gnr.com/stampfaq.htm -- the unofficial Stamp FAQ. There's been
a lot of cable questions lately!
Al Williams
AWC
* Easy RS232 Prototypes
http://www.awce.com/rs1.htm
From: mikasuon2004 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=51uv9_fuqN4O89pd95rNJ15D37BwfbzIc9U4QmuRo3eV5-jR8Ewq3mafs5FAkrWSsjPn77m1Sqa4AYzA]dumpkernel@h...[/url
Sent: Wednesday, April 28, 2004 1:31 AM
Subject: [noparse][[/noparse]basicstamps] No basic stamps found...
Any suggestions?
Yahoo! Groups Links
I'm really looking forward to your faq about this topic (hoping for
some nice pictures with all the pins connected to a serial cable).
I first tested with a "straight-through" cable and that didn't work.
Then I found this Yahoo-group and found a picture which differed
from the picture on the manual, meaning pins 2 and 3 were swapped.
It's really frustrating to own a basic stamp and not be able to
program it...:/
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> I'm not familiar with the picture you mention, but uncross pins 2
and 3! The
There's been
> Regards,
> Al Williams
> AWC
> From: mikasuon2004 [noparse][[/noparse]mailto:dumpkernel@h...]
didn't
Pins
swapped,
disabled
baud
source
> Any suggestions?
Subject and
> Yahoo! Groups Links
You'll spend far more time and energy chasing connection problems than a
serial cable will cost.
-- Jon Williams
-- Dallas Office
From: mikasuon2004 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sFzYcqkj_epDabEbXXxfrd-1bV1Z5dVzdCtpvJ3AnbXpvKmf0Oo16xA6rTwEYp8Vrvav4fSqLZZTxs5gqQ]dumpkernel@h...[/url
Any suggestions?
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
requesting that the group admistrator remove them from the archive to
prevent future issues. Please, if you insist on rolling-your-own cables
and boards, please use official Parallax sources (that is, from our
documentation or web site).
-- Jon Williams
-- Dallas Office
From: mikasuon2004 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=83jLRjXeBV4P3KF3V3YI9JBFRLwD3HchdKZqD5_MqolbyVFt51JstVlMQPEh_aNEOiiA0rpO3gSdT7cGaA]dumpkernel@h...[/url
Any suggestions?
I'm having the exact same problem as you. I just bought the BS2SX-IC
from ebay and I have plugged it up exactly the same as you and still
i get exactly the same results as you. yes to loopback, and echo but
no device is found. Anyways if you do figure out how to get it
working, can u please e-mail me how you did it at
one_ied_freakazoid@h...?
Thanks very much!
Jason Chechik
--- In basicstamps@yahoogroups.com, "mikasuon2004" <dumpkernel@h...>
didn't
Pins
swapped,
disabled
baud
source
> Any suggestions?
Have you been able to program your stamps yet? If not, here are a few
things to check:
1. If you have a PDA or Palm Pilot make sure to turn off the "Hot Sync"
button.
2. If you have a voltage meter, I want you to take some voltage
measurements with the cable and power supply connected to the stamp.
You should see:
-5v across Sout and Vss
-10v across Sin and Vss
5v across Res and Vss
5v across Vdd and Vss
If you have any more questions please feel free to e-mail us.
Dave
Dave Andreae
Tech Support
PH. 916-624-8333
Stamp Support/ stamptech@p...
Javelin Support/ javelinsupport@p...
SX-Support/ sxtech@p...
websites
parallax.com
stampsinclass.com
From: Jason Chechik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wEdjyRA7Fssv1vXZ_LbRHIFiRX52_ktMbbHE-Fe_wNlxKlw7yQMkjTE2X5OWKPo4o8nZZiPGbB28XT303yh0GR92Yd1p]one_ied_freakazoid@h...[/url
Sent: Wednesday, April 28, 2004 1:33 PM
Subject: [noparse][[/noparse]basicstamps] Re: No basic stamps found...
Hey Mike
Thanks very much!
Jason Chechik
didn't
Pins
swapped,
disabled
baud
source
> Any suggestions?
Yahoo! Groups Links
abuse@p....
No I still havn't gotten it to work and I don't have a PDA and I've
taken the measurments with my multimeter and those are the exact
readings I get. I'm thinking that it's the chip istelf, so I bought
a new BS2-IC I guess we'll find out soon. Anyways thanks for the
trouble i've put you through. And I'll keep you posted on the
results of my entire Basic stamp experience when I recieve the new
stamp.
Thanks very much!
Jason Chechik
--- In basicstamps@yahoogroups.com, "Dave Andreae" <dandreae@p...>
wrote:
> Hello,
few
> things to check:
Sync"
> button.
stamp.
> You should see:
> Thanks,
> Dave
> Dave Andreae
> Tech Support
> PH. 916-624-8333
> websites
> parallax.com
> stampsinclass.com
> From: Jason Chechik [noparse][[/noparse]mailto[noparse]:o[/noparse]ne_ied_freakazoid@h...]
> Hey Mike
IC
still
but
> Thanks very much!
> Jason Chechik
<dumpkernel@h...>
> didn't
> Pins
> swapped,
> disabled
assume
> baud
> source
> > Any suggestions?
Subject
> Yahoo! Groups Links
> abuse@p...
