wheel chair project
I'm building a wheel chair for a friend using two brushed motors that
are controlled by power modules opto-coupled to a BS2SX.
I can run the chair while sitting in it with my lap top using pulsout
and pause but want to change over to joystick control.
Is there a resource anyone knows about on how to use a joystick
(actually two pots)as an input device to control a chair?
The H-bridge forward/reverse is not the challenge, using an analog
input is what has me stumped.
thanks
chris
thanks
chris
>thanks
>chris
Chris -
Take a look here for wheelchair motor controllers, joystick interfaces, and
other similar equipment: http://divelec.tripod.com/id1.html . This all designed
for actual use on wheelchairs which a good deal of similar equipment is not.
Bruce Bates
that
pulsout
> thanks
> chris
Hi Chris,
The options for analogue input are pretty wide.
Read up on POT and RCTime as inputs to see if you can get the
resolution you need.
I am thinking you can get enough as for my experiances, you can live
with a handfull of 'steps' in the speed ranges.
If you can divide a pot input to 10 steps, then the wheel chair would
appear to shift gears as you moved up in steps. But, I'm betting you
can do much better than that.
Also,instead of a linear 1:1 output speed to input signal, I'd
recomend you try a much lower first gear. My experiance is more with
hi-lift jacks on construction sites, but the idea is the same.
the problem for is that I am not on them often enough and when I'm 20
feet in the air and want to nudge the thin forward a few inches, it
jumps and scares the be-geebers out of me.
I would much preferr a non-linear ramping with a very slow crawl to
start. And IMHO, the difference between 3/4 and full speed is not as
important.
And, if you want really high resolution, use out ChipCircuit-ADC. It
sandwiches between the Stamp and the stamp socket so add 10 channels
of 12 bit ADC. And the code snips are there so you can plug it in
and get it running quickly.
It may be overkill for your app, but it is worth a look.
http://www.visualmuses.com/chipcircuit/index.html
Dave
>thanks
>chris
Chris -
Bruce Bates
from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
SBC Yahoo! - Internet access at a great low price.
machine quality joysticks with real microswitches for input from.
http://hapcontrols.com They are relatively inexpensive as well.
$8.95 for the 4 position standard joystick. it operates in 8 positions
diagonally by accessing two switchs at once. I have used them for years and
never had a failure. Hap also sells high quality pushbutton switchs for a
few dollars.
Good luck.
-Kerry
At 05:37 PM 5/18/04 -0700, you wrote:
>If you don't 45 degree travel direction, how about using the the joystick
to operate forward ,back, left, right switches.
>>thanks
>>chris
>Chris -
designed
>Regards,
>Bruce Bates
>Yahoo! Groups Links
>Do you Yahoo!?
>Yahoo! Groups Links
Very respectfully, your obedient servant.
Brig. Gen. Johnston Pettigrew
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
input of the comparitor has a pulse train on it. As the joystick moves, it
changes the reference level, and the pulse train will have different widths
depending upon where it's at. Different widths translate into different
average power/Voltage levels to the motors.
From: Philip Gmblin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=v9iwKz2BJRjs0a0Jp2brNdo_wa0wNOnZjXPp-BWHj9hXDATQfeqG8TDU0t4zHdrkjTWLH3uU8lLCfFQO]pipeguy3153@y...[/url
Sent: Tuesday, May 18, 2004 8:37 PM
Subject: Re: [noparse][[/noparse]basicstamps] wheel chair project
If you don't 45 degree travel direction, how about using the the joystick to
>thanks
>chris
Chris -
designed
Bruce Bates
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
