PC Serial Port Flow Control
Confused about doing serial i/o through serial port to PC, via the
serin/serout pins. Not sure how to handle flow control and I've read
contradictory info (or so it seems).
I will be sending data in both directions and don't want to miss any
bytes. Don't want xon/xoff software bytes in the stream because I will
be sending binary data and don't want to handle escape sequences (messy).
I am writing the PC comm software (Java), so I can set whatever
options I need to. I see that I can connect DSR to DTR and RTS to CTS.
This makes the PC see hardware flow control? Or is this faked (e.g. no
real flow control)?
I imagine the PC has buffer space so sending to it is not too bad. But
from the PC to Stamp (BS2), how is it effectively throttled? My stamp
will have other duties so I think flow control is essential.
I am not an electronics person and fairly new to Stamps, but I've read
a ton of stuff so far. Stamp-Stamp serial comm. seems easier with the
explicit flow control pin.
Thanks for any help.
Harry
real flow control)?
Harry
Here's one approach that works. First and foremost, the PC never
sends the Stamp anything until the Stamp prompts the PC for data by
sending a code or command of some kind, and the Stamp doesn't send
that code or command until it is prepared to receive data (SERIN
follows immediately). Second, the PC waits a few msec before
actually transmitting data in response to the code/command from the
Stamp. Going the other direction, the serial port's buffer and the
PC's speed usually take care of data flowing from the Stamp to the
PC.
Steve
> contradictory info (or so it seems)...
*PC* *Stamp*
RTS from PC --> 27kohm resistor to p1 on Stamp
CTS on PC <-- 220 ohm p0 on Stamp
TX from PC --> Sin on Stamp (p16)
RX on PC <-- Sout on Stamp (p16)
COM --- COM
On the Stamp, use a command like this...
SERIN 16\0,$4054,6000,bailout,[noparse][[/noparse]zork]
The Stamp will hold p0 at a low level until it is ready to receive,
and the PC must look at its CTS line (Clear to Send), and wait up
until that line goes high before sending a byte to the Stamp.
The Stamp output looks like this:
serout 16\1,$4054,60000,bailout,[noparse][[/noparse]"A"]
The Stamp will only transmit when its p1 input (from the PC RTS line)
is high. So the PC should keep that line high unless it wants the
Stamp to hold off on sending it data. As you noted, that will not
usually be a problem unless there is danger of overrunning the PC
buffer.
If necessary, pace the transmission on the PC end to give time for
the Stamp to react. Some PCs have a transmit buffer that might not
react to the flow control signal from the Stamp on a byte to byte
basis.
If you use an inverting buffer like the MAX232 on the CTS/RST lines,
then the baudmode parameters become $54 for non-inverted, instead of
$4054 as written above. You could use the DTR/DSR pair, instead of
RTS/CTS, if that is more convenient.
-- Tracy
>real flow control)?
However, there is also a Javelin Stamp. The Javelin Stamp has a feature
called 'Virtual Peripherals'. From a programming point of view, a Virtual
Peripheral UART is like having a serial i/o input buffer. The VP UART has
methods: byteAvailabl( ) and receiveByte( ).
________
Sent: Sunday, April 25, 2004 6:54 PM
Subject: [noparse][[/noparse]basicstamps] PC Serial Port Flow Control
> real flow control)?
> Harry
> Yahoo! Groups Links
VB; it should be helpful:
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv89.pdf
-- Jon Williams
-- Dallas Office
From: harrybstoner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2hNeNI0oBq7WBtki9vA7TWrzlnPFjnhdCnyL--C9vk9pRwrVbct73ZaxpGcREnmrdls2T4N5pZuYRoRZ]tedstoner@1...[/url
Sent: Sunday, April 25, 2004 5:55 PM
(messy).
I am writing the PC comm software (Java), so I can set whatever options
I need to. I see that I can connect DSR to DTR and RTS to CTS. This
makes the PC see hardware flow control? Or is this faked (e.g. no real
flow control)?
I am not an electronics person and fairly new to Stamps, but I've read a
Harry
back to the PC -- you MUST have a MAX232 or
equivalent for that line. The other lines look
correct, though.
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Supposing you have the following connections:
> *PC* *Stamp*
> COM --- COM
line)
> buffer.
> basis.
lines,
of
> -- Tracy
CTS.
(e.g. no
> >real flow control)?
But
stamp
read
the
install it. I can afford 4 general purpose stamp i/o lines for this.
The nice thing is that this connection is then totally separate from
the connection used for downloading code for the stamp. So switching
from development mode to run time mode means just swapping one cable.
All confusion is cleared up (for now anyway).
Thanks.
Harry
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...> wrote:
> I don't think the BS2 can drive the CTS signal
> correct, though.
> > *PC* *Stamp*
> > COM --- COM
> line)
> > buffer.
> > basis.
> lines,
> of
> > -- Tracy
> CTS.
> (e.g. no
> > >real flow control)?
> But
> stamp
> read
> the
