DATA command
i have recently connected a 4x20 parallel LCD to my bs2, and found a
basic program to upload text. my understanding is that this program
writes the string i want to display to the eeprom of the stamp, and
then calls it back with the read command. my question is how to
change the DATA 'string' dynamically during program execution. any
help is appreciated
help is appreciated
a
program
> help is appreciated
The way that I've handled this is to modify the LCD code so that it
uses a variable which refers to a string to write. For example, here
is a variable used by the LCD routine:
lcdStr var word
Then, define some strings this way:
captions data " RPM HZ LOAD",0
calStr data "Calibrating...",0
manMode data "Manual Mode", 0
and then display a particular one this way:
lcdStr = calStr
gosub outputStr
The outputStr() subroutine should read bytes beginning at the
location referred to by 'lcdStr' and display them, stopping when it
gets to the zero byte at the end of the string. For example:
outputStr:
for i = 0 to 100
read lcdStr + i, lcdData
if (lcdData = 0) then outputStrDone
gosub sendLCDData
next
outputStrDone:
return
The sendLCDData() subroutine should output the byte given
by 'lcdData'.
location of your table (easy) and put some limit on its end so you don't
overwrite any tables that follow. StampWorks experiment 31 will help a
bit.
-- Jon Williams
-- Dallas Office
From: scomcleod [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AXT5k4lm5Bs-v19IeaBgePqo2ZXalQRs7dFygxb2ZnCotSjUpsRXL5co7kSS6RxYQ6IYgwi5LakMU7vCNA]scomcleod@y...[/url
Sent: Friday, April 23, 2004 9:16 PM
Subject: [noparse][[/noparse]basicstamps] DATA command
help is appreciated
Output_Str:
DO
READ lcdStr, lcdData
lcdStr = lcdStr + 1
IF (lcdData= 0) THEN EXIT
GOSUB Send_Lcd_Data
LOOP
RETURN
Since "lcdStr" is a variable that gets modified by the program, there's
no reason to use another variable to control loop that reads characters
from the DATA table.
-- Jon Williams
-- Dallas Office
From: Don Kinzer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LQZsvsbVGAqekDPjc2J_HczLnUe1_bfMVuMtfHRr1NcVFh6qJwx2Seav4UAPfbnqqVgAv97Cp5-xWDHsMCBCDQ]dkinzer@e...[/url
Sent: Saturday, April 24, 2004 1:39 AM
Subject: [noparse][[/noparse]basicstamps] Re: DATA command
--- In basicstamps@yahoogroups.com, "scomcleod" <scomcleod@y...>
a
program
> help is appreciated
lcdStr var word
lcdStr = calStr
gosub outputStr
outputStr:
for i = 0 to 100
gosub sendLCDData
next
outputStrDone:
return
by 'lcdData'.
