Variable Value Changes Unexpectedly
I have been having trouble with a variable whose value suddenly
changes. The variable is supposed to increment from 1 to 250 in
increments of one and then when it is greater than 250 the program is
to end. I am finding that suddenly for no apparent reason the byte
variable suddenly jumps to greater than 250 and the program ends and
the variable never completed the loop count. This happens
intermitently (sp??) and the program has to run several hours before
it does the "burp". I realize there could be many issues but I have
wrestled with this for some time and I'm starting to be suspicious
that it may be a memory pointer type of problem. According to my
memory map I have 11 bits of available memory left. I am not writing
to EEPROM anything using the WRITE statement and the variable is used
nowhere else except in this routine. Anyone have any ideas about what
could cause this?
Kind Regards,
Eric
could cause this?
Kind Regards,
Eric
these mysteries.
-- Jon Williams
-- Dallas Office
From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ss0aJepwLuzGhbTPCOnOPchl5p85FlToLoszVIku9MNV_x1TL7CgCHaPjrYdWGaZUZIu3aEuwXooi2GawQ]khufumen@y...[/url
Sent: Friday, April 23, 2004 3:56 PM
Subject: [noparse][[/noparse]basicstamps] Variable Value Changes Unexpectedly
could cause this?
Kind Regards,
Eric
--- Jon Williams <jwilliams@p...> wrote:
> Are you aliasing (overlaying) variables? This is
> usually what causes
> these mysteries.
> -- Jon Williams
> -- Dallas Office
> From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wJ8b7RpIP3tu6tMqJl5AGBUaIcXile3j5mc0dlKMejSxT9pI4qOU1dI21EdfR9taUrf-TwpHKhJ8JHP7zw]khufumen@y...[/url
> Unexpectedly
> value suddenly
> 1 to 250 in
> 250 the program is
> reason the byte
> program ends and
> happens
> issues but I have
> be suspicious
> According to my
> I am not writing
> variable is used
> ideas about what
> could cause this?
> Kind Regards,
> Eric
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
For example:
hrsBCD VAR Byte
hrs10 VAR hrsBCD.NIB1
hrs01 VAR hrsBCD.NIB0
While I have three definitions, only one byte of RAM is actually
defined. If hrsBCD gets changed, then the will be changes in hrs10 or
hrs01 or maybe both. And, if I change either hrs10 or hrs01, the WILL
be a change in hrsBCD.
-- Jon Williams
-- Dallas Office
From: Eric [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MN88c7nge9WabLpnYruZKyMEQdzuoMRIefYsZTZCVJLUZ1hV14hgMQJkWz-RiZTgA3GeRf5LDug]khufumen@y...[/url
Sent: Saturday, April 24, 2004 6:52 AM
Subject: RE: [noparse][[/noparse]basicstamps] Variable Value Changes Unexpectedly
Unsure as to what you mean by aliasing variables?
> usually what causes
> these mysteries.
> -- Jon Williams
> -- Dallas Office
> From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MN88c7nge9WabLpnYruZKyMEQdzuoMRIefYsZTZCVJLUZ1hV14hgMQJkWz-RiZTgA3GeRf5LDug]khufumen@y...[/url
> Unexpectedly
> value suddenly
> 1 to 250 in
> 250 the program is
> reason the byte
> program ends and
> happens
> issues but I have
> be suspicious
> According to my
> I am not writing
> variable is used
> ideas about what
> could cause this?
> Kind Regards,
> Eric
aliased. Works great now. Thank you very much for your
help.
Eric
> Aliasing refers to giving the same RAM location two
> different names.
> For example:
> hrsBCD VAR Byte
> is actually
> changes in hrs10 or
> or hrs01, the WILL
> -- Jon Williams
> -- Dallas Office
> From: Eric [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XpWKkScq18bH22LWph6M6eg4A5NMF7-UV7q5Qf9JKJNqjx7SiXiNdpxdULCSETZDD9vubVAxxwjCzA]khufumen@y...[/url
> Unexpectedly
> > usually what causes
> > these mysteries.
> > -- Jon Williams
> > -- Dallas Office
> > From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XpWKkScq18bH22LWph6M6eg4A5NMF7-UV7q5Qf9JKJNqjx7SiXiNdpxdULCSETZDD9vubVAxxwjCzA]khufumen@y...[/url
> > Unexpectedly
> > value suddenly
> from
> > 1 to 250 in
> > 250 the program is
> > reason the byte
> the
> > program ends and
> > happens
> > issues but I have
> to
> > be suspicious
> > According to my
> left.
> > I am not writing
> the
> > variable is used
> any
> > ideas about what
> > could cause this?
> > Kind Regards,
> > Eric
> ignored.
> Yahoo! Groups Links
