A diferent transducer - water flow measurement
Hi Spence,
Since we all know you like all caps. we'll not go there (again)
That looks good and will be a neat device for many of us. One thing
that most of us look for is cheap. the larger meters start to cost a
pretty penny.
A very workable solution is to take your 2" or 8" pipe and add an
orifice plate. Just a plate with a slightly smaller diameter than
the pipe size.
This creates a pressure drop that should not be too great, but will
offer a benefit to this meter.
Then you can place the smallest meter so it is connected on both
sides of the plate and the meter will show a representative flow of
water.
another approach is to put a sensor in the main pipe that faces the
direction of flow and one that faces opposite the direction of flow.
That way, the meter would see a representative flow.
But, this is neat as I am working on a project for a greenhouse data
logger and monitoring water quantity would be a neat additional
point !
The home-brew version of this would be a Tee in the pipe and a paddle
wheel in the Tee so that the axis was hidden from the main flow up,
inside of the tee. Then on the paddle wheel one wheel (or more)
would have a metal bit so a sensor could count pulses each time that
part passed the sensor. The sensor could be on the cap on the tee.
If anyone is interested, I can work up a sketch.
Dave
--- In basicstamps@yahoogroups.com, "BOYD S.(SPENCE) MINER"
<k4kep@b...> wrote:
> EXCUSE THE ALL CAPS.
> I FOUND THIS ON THE X-10 GROUP LIST AND THOUGHT SOME ON HERE MIGHT
JUST
> BE INTERESTED IN HOME ECO MONITORING .
> SOME MODELS OF THE METERS HAVE CONTACTS WHICH INDICATE AS LOW AS
1/10
> GALLON OF FLOW. FOR THE STAMP USER, THIS WOULD WORK WITH THE BUTTON
SYNTAX.
> THIS TYPE METER WOULD MAKE IT EXCEPTIONALLY EASY TO IMPLEMENT WATER
> MONITORING SO THAT IN EVENT OF A FREEZE OR OTHERWISE BROKEN PIPE,
YOU
> WOULD GET A INDICATION RATHER QUICKLY.
> 73
> SPENCE
> K4KEP
> Message: 1
> Date: Thu, 22 Apr 2004 08:46:32 -0400
> From: "Joe Zimmerman" <zimmer62@e...>
> Subject: Water meter monitoring.
> Per the discussion on homeseer forums
> http://ubb.homeseer.com/eve/ubb.x?
a=tpc&s=697298074&f=308298074&m=7896016835
> We have found a water meter that fits the job perfectly to monitor
our water
> usage, figured someone else in this forum might have some interest.
> http://www.jerman.com/dljmeter.html
> jerman has a 3/4 to 3/4inch meter that has 1/10 resolution so it'll
give you
> a pulse for every 1/10 of a gallon you use.
> Anyways, if we buy 20 or more of these he'll give us $10 off per
unit making
> them $109.95 per unit.
> If there is any interest let me know.
> Joe Zimmerman
> From: "Jon Jerman Jr" <jonNOSPAMjr@w...>
> To: "'Joe Zimmerman'" <zimmerNOSPAM62@e...>
> Sent: Thursday, April 22, 2004 8:04 AM
> Subject: RE: water meters.
> >> Joe,
> >> In 20+ units I could knock $10 each off of the price, but no
more than
> that.
> >> Let me know.
> >> Jon Jerman, Jr.
> >> www.watermeters.com www.jerman.com www.dljmeter.com
> >> www.oilmeters.com www.febcobackflow.com www.fire-
sprinkler.com
> >> 800.654.3733 201.487.7444 Fax 201.487.3953
> >> Daniel L. Jerman Co., 275 Railroad Place, Hackensack, NJ 07601
pretty penny.
the pipe size.
water.
point !
Dave
JUST
1/10
SYNTAX.
YOU
> 73
> SPENCE
> K4KEP
> Message: 1
our water
give you
unit making
> Joe Zimmerman
> >> Joe,
more than
> that.
> >> Let me know.
> >> Jon Jerman, Jr.
sprinkler.com
