Cheapest Way to Read Temperature
I am looking for a cheap way to read temperature of a room. The
DS1822 in on and engineering hold and they have no sub. I was
looking for something like it that doesn't cost a lot.
Troy
Troy
> Troy
Hi Trouy,
a simple PN junction with an op-amp will offer a response with
temperature.
More parts, but should be stuff you have laying around.
a couple pots, a diode for temperature measurement and an op-amp.
Of course it needs calibration, but the cost is quite possibly less
than a quarter.
How cheap were you looking ?
Dave
stand-by DS1620 (3-Wire) or its I2C cousin the DS1621.
-- Jon Williams
-- Dallas Office
From: Troy Bakken [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PVwGahBRvaH8_h_q2w1f5KRrHXaN6cDJQ7ABPC_vAtZfWJQBnaIoIDyjKPbZbYjTsxZABtH4Jkt9DDU]troybakken@y...[/url
Sent: Thursday, April 22, 2004 6:03 PM
Subject: [noparse][[/noparse]basicstamps] Cheapest Way to Read Temperature
Troy
Just hooked up yesterday and it works alright.
I'm not satisfied with how it's changing temp but I'm now thinking that as
I'm programming and monitoring the debug statements....I realize it was
sitting beside my fan exhaust port on the laptop!! haha
I knew it didn't feel like 80 in the office!
LM35's are another one....but it gives an analog voltage out so you'll need
an A/D or some RCtime work!
sb
Sent: Thursday, April 22, 2004 7:03 PM
> Troy
> Yahoo! Groups Links
With this thermistor, and a capacitor, use the rc time constant command to
return a pulse time. Put the thermistor in water with ice floating in it
for 32 F. Put the thermistor in water with steam coming off of it (close
enough to boiling) for 220F. Read the RC time constant value for both. Use
a scale factor (with offset) to have the stamp tell you the degrees in F
from those two known values.
The thermistors are within 1% of each other, so you can use the same scaling
for all measurements (assuming your capacitors are of similar quality).
This should get you close enough.
Only 2 parts for each measurement pin.
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RxZ0DASl3T_LmpY8xkL1YxxCnwRQnv0Wcj8BHUID_0dOr0sICFLYn2VG4ppBO1Os5dxx7dAYFfiCDp_b]davemucha@j...[/url
Sent: Thursday, April 22, 2004 7:14 PM
Subject: [noparse][[/noparse]basicstamps] Re: Cheapest Way to Read Temperature
--- In basicstamps@yahoogroups.com, "Troy Bakken" <troybakken@y...>
> Troy
Hi Trouy,
temperature.
than a quarter.
Dave
Yahoo! Groups Links
while and think they are just perfect. Costly yes, unless you may
get a few from Dallas for free.
Lars
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> 1-Wire parts are a pain in the backside anyway ... I'd suggest the
old
> -- Jon Williams
> -- Dallas Office
> From: Troy Bakken [noparse][[/noparse]mailto:troybakken@y...]
> Troy
