Programming help ( Serin)
Hi all,
does anyone know how to use the command "SERIN" to extract the string of
data through a pin on BS2 from the GPS that is interfaced on BS2?
thanks for your help
Jeff
_________________________________________________________________
MSN Toolbar provides one-click access to Hotmail from any Web page – FREE
download! http://toolbar.msn.com/go/onm00200413ave/direct/01/
Jeff
> Does anyone know how to use the command "SERIN" to extract the
> string of data through a pin on BS2 from the GPS that is
> interfaced on BS2?
The Basic Stamp Programming Manual that I saw (v2.0c) gave lots of
information and examples in the section on SERIN. Not knowing the
output format of your GPS device, there's no way that anyone here can
give you specific information.
If you don't have the manual, you can get it here:
http://www.parallax.com/dl/docs/prod/stamps/BasicStampMan.pdf
Here is a code that was done a while ago, it's not commented but
it does work. It should help you.
'{$STAMP BS2}
'{$PBASIC 2.0}
'Setup for TRIPMATE GPS system
'reads 16 bytes of data each time via the $GPRMC mode
bytearray VAR Byte(16)
x VAR Byte
x1 VAR Byte
x2 VAR Byte
x3 VAR Byte
x4 VAR Byte
x5 VAR Byte
t VAR Byte
t1 VAR Byte
t2 VAR Byte
t3 VAR Byte
HIGH 9
start:
SERIN 8,188+$4000,60000,nodata,[noparse][[/noparse]WAIT("$GPRMC"), STR bytearray\16]
DEBUG STR bytearray\16,CR
x=bytearray(10)
x1=bytearray(11)
x2=bytearray(12)
x3=bytearray(13)
t=bytearray(1)
t1=bytearray(2)
t2=bytearray(3)
t3=bytearray(4)
x4=bytearray(5)
x5=bytearray(6)
DEBUG "Time ",STR t\1,STR t1\1,":",STR t2\1,STR t3\1,":",STR x4\1,STR
x5\1," GMT",CR
SERIN 8,188+$4000,60000,nodata,[noparse][[/noparse]WAIT("$GPRMC"), STR bytearray\16,STR
bytearray\16]
x4= bytearray(4)
DEBUG "Latitude ",STR x4\1,STR x\1,STR x1\1,223,STR x2\1,STR x3\1,CR
x=bytearray(6)
x1=bytearray(7)
x2=bytearray(8)
x3=bytearray(9)
x4=bytearray(10)
bytearray\16,STR bytearray\16]
x5=bytearray(1)
DEBUG "Longitude ",STR x5\1,STR x\1,STR x1\1,STR x2\1,223,STR x3\1,STR
x4\1,CR
x=bytearray(12)
x1=bytearray(13)
x2=bytearray(14)
x3=bytearray(15)
bytearray\16,STR bytearray\16,STR bytearray\16\"*"]
DEBUG STR bytearray,CR
IF x="," THEN cc
IF x1="," THEN aa
x=x3
x1=bytearray(0)
t=bytearray(1)
t1=bytearray(2)
t2=bytearray(3)
t3=bytearray(4)
GOTO bb
aa:
x=x2
x1=x3
t=bytearray(0)
t1=bytearray(1)
t2=bytearray(2)
t3=bytearray(3)
GOTO bb
cc:
x=x1
x1=x2
t=x3
t1=bytearray(0)
t2=bytearray(1)
t3=bytearray(2)
bb:
DEBUG "Date ",STR t\1,STR t1\1,"/",STR x\1,STR x1\1,"/",STR t2\1,STR
t3\1,CR
GOTO start
nodata:
DEBUG "bad connection?",CR
GOTO start
Stephen Swanson
Technical Support Manager
599 Menlo Drive, #100
Rocklin, CA 95765
Phone (916) 624-8333
E-mail ..... sswanson@p...
Main site...... www.parallax.com
Educational site.... www.parallax.com/sic
Javelin Stamp... www.parallax.com/javelin
From: Wu MengChe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2e6xLjk_45-oPS6trMcvbeXyvrbeQO9T5ow0fZlrI4bcAC22EnkfqTR2dHH6GLq0P2vqGEgQRuhKrnk]mengche@h...[/url
Sent: Thursday, April 22, 2004 9:44 AM
Subject: [noparse][[/noparse]basicstamps] Programming help ( Serin)
Hi all,
Jeff
MSN Toolbar provides one-click access to Hotmail from any Web page -
FREE
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
