Converting GPS Coded ASCII (NMEA) Into Binary???
I'm Trying to Interface My GPS Reciever with my BS2, The Reciever
Spits out 8 to 12 different lines of ASCII Code (NMEA National
Marine Encoded Ascii or somthing) in a nearly random pattern. Each
line starts with an Identifier, The One I'm Working with
is "$GPRMB", Then the individual Data sections of the line separated
by Commas..
$GPRMB,A,9.9,l,,,,,,,,A,
I'm Not smart enough to get that to interface with my BS2. If I need
extra hardware, Okay, If it's a software thing okay, I just need a
Shove in the right direction. Thanks..
by Commas..
[noparse][[/noparse]interesting details removed]
>I just need a Shove in the right direction.
<SHOVE>
http://www.parallax.com/dl/docs/cols/nv/vol4/col/nv103.pdf
</SHOVE>
[noparse];)[/noparse]
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
