bluetooth enabled printer
Im currently doing a project on a bluetooth enabled printer. I have
BS2 connected to the BOE,a serial to parallel printer chip(EDE 1400)
and EB500 connected to BOE. On the other side, im using a bluetooth
dongle to connect the circuit via hyper terminal. All the connections
and intialisation went smoothly execpt that im stuck at how to
transfer an imgae file to the EB500. And still cant figure out how to
print the received image file through the printer. Can anybody help
me with a sample program or suggestions on how to transfer an image
file?
Thanks.
Leo
file?
Thanks.
Leo
The easiest way to implement Bluetooth printing using a Basic Stamp
is to make the module a simple pass through once a connection has
been established. You want to route all data received by the eb500
module from the PC directly to your printer. If your printer is bi-
directional you also want to route all data from the printer back up
to the PC. This can be quite simple or somewhat complex depending on
which Basic Stamp you are using.
1. If you are not using hardware flow control, you need to ensure
that data does not get missed. If you are sending large amounts of
data from the PC, a BS2 at 9600bps will have a hard time keeping up
without missing data while its writing to the printer.
2. If you are using the Javelin Stamp the task is quite easy because
it is a faster processor and has a UART buffer. You do not need to
be nearly as careful to ensure that no data is missed.
With this pass through scheme, the printer will behave as if it were
connected directly to the PC via a serial cable. Neither
HyperTerminal nor a printer driver will be able to tell the
difference.
Sincerely,
Bryan Hall
A7 Engineering
http://www.a7eng.com
